6R 1.6TDI 90HP CAYB 2009
Ugabista
Drives: Vw Polo 6R 1.6TDI 90CV CAYB
Re: 6R 1.6TDI 90HP CAYB
Post by Ugabista »
ciclo wrote:
Ugabista wrote: - The climatic error could never erase, back forever, but I do not know what it is because the climatic seems to work well.
- The errors of navigation seems to be the antenna, loose connection maybe.
- The telephone will not know why, the microphone seems to me well connected.
Climatic
Try making an auto scan with the engine running and first speed fan switch.
Antenna
You must have an aftermarket antenna installed.
Telephone
I think the problem is the wiring. You have to have one like this.
Be configured with SDS.
http://www.carsystems.pl/bluetooth-wiri ... id165.html
The coding unit telephone is correct.
Climatic
Address 08: Auto HVAC (J301) Labels: 6R0-820-045.clb
Part No SW: 6R0 820 045 E HW: 6R0 820 045 E
Component: Climatic 24 0600
Revision: 00 10 24
VCID: 306FF64B63D6889E243-8065
1 Fault Found:
16372 - Control Module; Unspecified Internal Error
014 - Defective
Fault Status: 01101110
Fault Priority: 1
Fault Frequency: 1
Reset counter: 255
Mileage: 31090 km
Time Indication: 0
Date: 2013.14.04
Time: 21:04:20
Same? :(
Antenna:
The antenna is the source I have is this adapter, you can be here?
http://www.aliexpress.com/item/Antenne- ... 61436.html
Telephone:
I have these cables: http://www.aliexpress.com/item/Original ... 73702.html
No good? Or do not give this bluetooth module but may give another?
This bluetooth module is a friend of mine who had a VW Passat which sold and was working well there, lent me to see what allowed in my car, do not know if more can I have another basic or not the same features on my car.
Thanks. :)
Component: TELEFON H15 3200 Bluetooth module is right, the problem is the wiring.
The antenna base must be OEM, the adapter cable is correct.
Climatic fault is common, no problem for it, try again with A/C ON. Delete DTCs.
If you have installed this antenna vcds faults are normal.
Ugabista
Post by Ugabista »
ciclo wrote:Component: TELEFON H15 3200 Bluetooth module is right, the problem is the wiring.
WTF!! The cheap is expensive :cry: Cables for the trash or give to invent these?
I do not have that antenna yet, beaten badly and went back to the original place. I have to better see what is happening on the antenna socket .
I have tried in every way clear the error and I can not, engine on and off, ac on and off, various speeds and different air distribution and nothing, researching claims to be an internal module but not any notice anything unusual in the operation of AC... :roll:
Ok, then check the antenna cable connectors. Front and rear. :wink:
Ugabista
Post by Ugabista »
ciclo wrote:Ok, then check the antenna cable connectors. Front and rear. :wink:
6R0 035 501C on the way :)
I have to try other cables in this bluetooth module in my car and these cables in another car with bluetooth module in order to justify the seller and give me the money this crap... so then buy those in carsystems :wink:
Ugabista
Post by Ugabista »
The seller told me that this bluetooth module (7P6 035 730 J) is not compatible with the RNS 315, only works with RCD510 and the RNS510, it will be possible ??
What about this ?? http://jku.com.au/genuine-vw-oem-premiu ... rettyPhoto
Ugabista
Post by Ugabista »
There he is!! :lol:
The problem is not the phone unit. It has the correct software and hardware (Component: TELEFON H15 3200).
I think the problem is the wiring and you have two options:
1- Modify your current wiring in this way. :twisted:
2- Buy CARSYSTEM wiring. (my recommendation)
The last software that greatly improves the bluetooth audio is 4217, works better than 3200
For example, a complete kit would be this: http://www.carsystems.pl/vw-bluetooth-k ... id886.html
Ugabista
Post by Ugabista »
ciclo wrote::)
Thank you once again for all the help friend :)
The desirable would buy this wiring carsystems but for now just wanted to put it to work and solve this microphone problem, possibly after buy this link kit you placed, sounds good :lol:
Looking at the diagram you placed, as I understand, will modify or replace the positive with the negative? Not quite understand .. :oops:
You are a well of knowledge and have electric schemes for everything, awesome, you should be my neighbor :D
All you have to do is add directly a wire from pin 7 connector 12-pin to the wire "positive audio" mic before the bluetooth phone unit.
Easier (plug and play) is to buy CARSYSTEM wiring.
Ugabista
Post by Ugabista »
ciclo wrote:All you have to do is add directly a wire from pin 7 connector 12-pin to the wire "positive audio" mic before the bluetooth phone unit.
Okay, tomorrow I will have to make this direct link.
When can i order this KIT: http://www.carsystems.pl/vw-bluetooth-k ... id886.html
Thank you very much.
Regarding the error I have in Climatic (08), was to do some more tests and I came across this discrepancy in values in the third frame, will be normal?
Revision: 00 10 24
1 Fault Found:
014 - Defective
Fault Priority: 1
Fault Frequency: 1
Reset counter: 255
Mileage: 31090 km
Time Indication: 0
Date: 2013.14.04
Time: 21:04:20
Ugabista
Post by Ugabista »
This wiring is already plug & play, that is, the negative (1) and the positive (7) will direct the 12-pin to the micro, not through the Bluetooth Unit, measure continuity with a multimeter and are good .. :(
Why will the error in the VCDS? What will it be?
The people on the other side does not hear me and hear in echo but I hear the person well....:cry: :cry:
Ugabista
Post by Ugabista »
Add = +
So to the pin7 should arrive two cables. Try it.
Ugabista
Post by Ugabista »
ciclo wrote:Add = +
Thank you for your answer Ciclo, but today I could make everything work in this way.
Address 77: Telephone Labels: 7P6-035-730.clb
Control Module Part Number: 7P6 035 730 J HW: 7P6 035 730 J
Component and/or Version: TELEFON H15 3200
Software Coding: 0611000000010110
Work Shop Code: WSC 00015 115 12345
ASAM Dataset: EV_UHVNA 002720 (VW25)
VCID: 3979CB6FB8AC49D693D-806C
:lol:
