FBZ Polo's
Re: FBZ Polo's
firebulletz wrote: Mon Oct 15, 2018 7:14 pm Hi,
I am back!
Hi.
firebulletz wrote: Mon Oct 15, 2018 7:14 pm I have buyed a chinese autolights switch with ch/lh function. I have used more than one types of manual but ch/lh not work. I have buyed the switch with external module with sensor. I don't know what is the problem.
https://uploads.tapatalk-cdn.com/201810 ... 44a388.jpg
The mystery of non-OEM parts. :lol:
Our ex-9N3 with an identical Kit worked correctly (CH/LH, automatic lights) with some functioning deficiencies related to the parking lights/turn signals (P symbol on left stalk)... long story... :)
Don't throw the light switch in the trash, it can be useful. :mrgreen:
firebulletz
Drives: Polo comfortline 1.6 tdi 90cv
Re: FBZ Polo's
Post by firebulletz »
Hi ciclo,
Is the switch defected?[emoji28]
Re: FBZ Polo's
I think the switch is fine. The problem is the other stuff lol
firebulletz
Re: FBZ Polo's
And what i have to do to fix the problem?
Inviato dal mio SM-G935F utilizzando Tapatalk
Re: FBZ Polo's
The Kit is plug and play. "It should work" from the first second it's installed.
firebulletz
Re: FBZ Polo's
Ok[emoji24]
I need to know if it's possible to install this:
https://youtu.be/-WzF103INkY
firebulletz
Re: FBZ Polo's
No one know if there is the correct pin to connect it?
Re: FBZ Polo's
I don't think the pins are the problem, but you'll have to drill a hole somewhere to guide the cable. You can just connect it to the same wires as the interior lights (take the plus from the red/black, minus from brown/black).
Re: FBZ Polo's
firebulletz wrote: Sun Oct 21, 2018 9:40 pm No one know if there is the correct pin to connect it?
+ ve = BCM T73a/65 wire, that is, the same wire as for footwell lights, dome lights, etc ...
In the 6R all the interior lights have the same power supply (the previous one), the difference between them is in the "ground wire".
For an easy electrical installation, use BCM T73a/4 wire, that is, the other wire -"ground wire"- of footwell lights. For a somewhat more complex installation use the door switch of each door. (read thealbert thread in this forum)
Hmm ... I wouldn't install that. :lol:
firebulletz
Re: FBZ Polo's
I have connected the negative to pin n°3 of locking door connector and positive to n°16 pin of window motor, but the light not work
Update
Ciclo, your scheme work perfectly, i have connected the lights. I only have a problem on driver door.
When i open the door the light will open for one second and after will turn off. The light will remain on only if I leave the door open for about 6-7 seconds, after which it will open and remain lit. I have the same problem with the ceiling lights. if I open the door the lights come on after about 6-7-10 seconds with the open door.
What can it be?
Re: FBZ Polo's
Maybe, the problem may be caused by other retrofits. The BCM is not managing some signals correctly, or rather, it is managing it correctly but the result is not as expected.
I would say it is related to your big radio screen (non-OEM) and its managment, ...but I can be wrong.
According to your comments, the lights installation on the door sills is "correct". However, check again that the splice in the wire going to :arrow: T8f/3 -driver door- is in good condition.
