FBZ Polo's
firebulletz
Drives: Polo comfortline 1.6 tdi 90cv
FBZ Polo's
Post by firebulletz »
Hello everyone,
start by saying that I love this forum and I apologize if I do not write a perfect English. You are always active, helpful, kind and informed.
For those who do not know me I introduce myself: My name is Salvatore, I'm 24 years old and I'm Italian. I bought my first polo with 210.000km, and despite this I am satisfied to have bought it. Unfortunately or fortunately I love to personalize my cars as I like them, and polo is perfect for this.
Mine is a Polo 6r Comfortline of 2011, purchased without any options, only with immobilizer. I have made some changes and will continue to do so.
Changes made:
- 10.1" android radio Sinosmart
- On-board computer and cruise control
- Golf 7 R-Line Steering wheel with controls
- Second trunk light
- Blue neon strip on door panels (work in progress)
- Rear camera
I have to thank infinitely ciclo, without which I would never have installed the steering wheel controls
Changes that I will make:
- Footwell lights
- Lights under the doors
- Auto-lights with switch and sensor (aftermarket) with CH/LH
- Parking sensor (aftermarket)
- Rear camera OEM
- Headlights full led polo 6c (if possible) or headlights aftermarket (golf 7 style)
- Tail lights (aftermarket)
And many other little things that I do not remember now
I am currently trying to figure out how to take the +12v signal, to connect the blue neon strips, from one of the car's interior lights (for example, from the headlight switch or the window switch light), in order to use the regulator lights inside to check the neon strips. It would be better to be able to take the signal from each door connector, not to have to pass the cables through the whole car.
Alternatively I could take the signal from the dipped headlights, so when the leaving home is activated (when I install it) the neon strips will also be activated. In your opinion, what is the best option?
I wish I could upload some photos, but it is currently so dirty that it turns brown from blue.
I'll upload them shortly
This is my actual autoscan:
Monday,26,March,2018,19:50:13:00001
VCDS -- Windows Based VAG/VAS Emulator Running on Windows 10 x86
VCDS Version: 17.8.0.1
Data version: 20170721 DS276.2
www.Ross-Tech.com
VIN: WVWZZZ6RZCY080849   License Plate:
Mileage: 212360km-131954mi   Repair Order:
Chassis Type: 6R-VW25 (6N0)
Scan: 01 03 04 08 09 15 17 19 25 37 44 56
VIN: WVWZZZ6RZCY080849   Mileage: 212360km-131954miles
37-Navigation -- Status: Not registered 0011
56-Radio -- Status: Malfunction 1010
Address 01: Engine (J623-CAYB)       Labels:. 03L-906-023-CAY.clb
   Part No SW: 03L 906 023 MA    HW: 03L 907 425 B
   Component: 1,6l R4 CR td H33 8849
   Revision: --H33---    Serial number:
   Coding: 00114016002400080000
   Shop #: WSC 00788 648 00255
   ASAM Dataset: EV_ECM16TDI02103L906023MA 003004
   ROD: EV_ECM16TDI02103L906023LL.rod
   VCID: 71E8ED58A0A91BCE75-8024
Readiness: 1100 0000
Address 03: ABS Brakes (J104)       Labels:. 6R0-907-37x-ESP82.clb
   Part No SW: 6R0 907 379 AK    HW: 6R0 907 379 AF
   Revision: --------
   Coding: 210228E3417500B2842D14E682DA00421100
   VCID: 071CA380B22D357ECB-8052
Address 08: Auto HVAC (J301)       Labels: None
   Part No SW: 6R0 820 045 G    HW: 6R0 820 045 G
   Component: Man AC         02 0101
   Revision: 0002S 02
   VCID: 326A22546D2F60D64C-8066
   Part No SW: 6R0 937 087 K    HW: 6R0 937 087
   Component: BCM PQ25 H+4  H46 0251
   Revision: BF046001    Serial number: 0434 237113707
   Coding: 3CB02BBF08A10000003808006D0B0CD00080412F60860060200000000000
   Shop #: WSC 124697 483 00190
   VCID: 45806988CCA1E76EF9-8010
   Subsystem 1 - Part No SW: 6R0 959 801 AB    HW: 6R0 959 801 AB  Labels: 6R0-959-801.CLB
   Component: J386__TSG_FT  008 1611
   Serial number: KU0KU025081100010210
   Coding: 18BC30
   Subsystem 2 - Part No SW: 6R0 959 802 AD    HW: 6R0 959 802 AD  Labels: 6R0-959-802.CLB
   Component: J387__TSG_BT  008 1611
   Serial number: KU0KU001091100015461
   Coding: 08BC30
   Subsystem 3 - Part No SW: 1K8 959 442     HW: 1K8 959 442
   Component: E221__MFL-DC1  H04 0103
   Serial number: 39170001271300057197
   Coding: A4FFFF
   Subsystem 4 - Part No SW: 6R0 959 811 G    HW: 6R0 959 811 G
   Component: J388__TSG_HL  008 1611
   Serial number: KU0KU017081100014087
   Coding: 08BC32
   Subsystem 5 - Part No SW: 6R0 959 812 G    HW: 6R0 959 812 G
   Component: J389__TSG_HR  008 1611
   Serial number: KU0KU030081100014426
   Coding: 08BC32
1 Fault Found:
00975 - Heated Rear Window (Z1)
            012 - Electrical Fault in Circuit
                    Fault Status: 01101100
                    Fault Priority: 3
                    Fault Frequency: 1
                    Reset counter: 142
                    Mileage: 212186 km
                    Time Indication: 0
                    Date: 2012.08.12
                    Time: 13:35:19
   Component: VW10Airbag022 H09 0020
   Revision: --------    Serial number: 003GX00UZUX8
   Coding: 003232
   VCID: 4A9A5AB4EDBF081614-801E
   Serial number: 3575HRB40690OCUIB06N
   Serial number: 3585HRB40690OCUIDPHJ
   Serial number: 3515RRB405B0M98E4981
   Serial number: 3525RRB40650MFP6O92Q
Address 17: Instruments (J285)       Labels:| 5K0-920-xxx-17.clb
   Part No SW: 6R0 920 861 H    HW: 6R0 920 861 H
   Component: KOMBI         H04 0206
   Serial number: 00000008663469
   Coding: 540A00
   ASAM Dataset: EV_DashBoardUDSJCIPQ25 A01015
   ROD: EV_DashBoardUDSJCIPQ25_A01_VW25.rod
   VCID: 3A7A0A74BD5F989684-806E
   Part No SW: 6N0 909 901     HW: 6R0 937 087
   Component: GW-K-CAN TP20 H46 0251
   Revision: BF046001
   Coding: 002200
   VCID: 70EEE85CA3A312C67A-8024
2 Faults Found:
            000 -  -
                    Fault Status: 01100000
                    Fault Priority: 2
                    Fault Frequency: 28
                    Reset counter: 255
                    Mileage: 212243 km
                    Time Indication: 0
                    Date: 2012.08.13
                    Time: 13:04:11
01304 - Radio
                    Fault Status: 00100100
                    Fault Priority: 2
                    Fault Frequency: 30
                    Reset counter: 191
                    Mileage: 212184 km
                    Time Indication: 0
                    Date: 2012.08.12
                    Time: 11:29:38
Address 25: Immobilizer (J285)       Labels:. 5K0-920-xxx-25.clb
   Component: IMMO          H04 0014
   Serial number:
   ASAM Dataset: EV_ImmobUDSJCIPQ25 A01001
   ROD: EV_ImmobUDSJCIPQ25.rod
Address 37: Navigation
Cannot be reached
   Part No: 6R0 423 156 B
   Coding: 11220
   Shop #: WSC 00788
   VCID: 2F6C2B20EA1D4D3E23-807A
Address 56: Radio
Cannot be reached
End-------------------------(Elapsed Time: 03:13)--------------------------
Inviato dal mio SM-G935F utilizzando Tapatalk
Re: FBZ Polo's
hey at least you got electric windows in the back from factory :P a luxury my car didn't even have :mrgreen:
firebulletz
Re: FBZ Polo's
iichel wrote:hey at least you got electric windows in the back from factory [emoji14] a luxury my car didn't even have :mrgreen:
Ahahah yes, i was only have immobilizer and electric windows in the back[emoji23][emoji23]
Re: FBZ Polo's
Welcome Salvatore (again :wink:)
firebulletz wrote: Mon Mar 26, 2018 8:27 pm
:lol:
Please show us images of those blue neon strips installed. (although you have already shown them, show them here).
Post here the link where you bought them. The info provided by the seller is important.
Are you able to tell us what's the real consumption of those blue neon strips using a multimeter?
firebulletz wrote: Mon Mar 26, 2018 8:27 pm Alternatively I could take the signal from the dipped headlights, so when the leaving home is activated (when I install it) the neon strips will also be activated. In your opinion, what is the best option?
No, there are better solutions and everything will work according to your wishes.
By the way, due to the installation of your new great/big radio 8) , you must disable the radio and navigation from the Gateway installation list.
firebulletz
Re: FBZ Polo's
ciclo wrote:Welcome Salvatore (again :wink:)
[emoji38]
This is the link of product:
http://s.aliexpress.com/ABJje6J3?fromSns=Copia negli appunti
Now i can't measure actual consumption, I will do it as soon as possible
This is the blue neon strip (connected at the moment with original usb)
Re: FBZ Polo's
4W/m... hmm.. take the power from:
T10/9 driver's door window switches.
T4/2 in the rest of the doors for the window switches.
Driver's door window switches:
+ve
They will be attenuated with the Dimmer and will light in case of automatic lights (any model :lol:). Like the rest of red interior lights for switches..
firebulletz
Re: FBZ Polo's
ciclo wrote:4W/m... hmm.. take the power from:
+ve
They will be attenuated with the Dimmer and will light in case of automatic lights (any model [emoji38]). Like the rest of red interior lights for switches..
It work! But i can't know where i can take negative signal. On door there isn't any metallic part with negative signal
Re: FBZ Polo's
any brown wire will do, i.e. at the switches or at the window regulator motor.
firebulletz
Re: FBZ Polo's
Yeeessss
After a few seconds it starts to go out and re-ignite continuously, like a light bulb that is about to burn. I have to check if the connector I used works well or if it is the faulty transformer.
I have used this connector to take the signals:
The effect that from this strip is really nice:
I do not know why it turned out upside down[emoji23]
Re: FBZ Polo's
Maybe the LED is not suitable for dimming? Does it change when you move the instrument dimmer?
firebulletz
Re: FBZ Polo's
iichel wrote:Maybe the LED is not suitable for dimming? Does it change when you move the instrument dimmer?
It not change. It continue to make noise.
firebulletz
Re: FBZ Polo's
I found the problem. The inverter is for 5v while now it is working at 12v. I think the problem is this.
Is there a way to get the 5v or do I first buy a 12v inverter?
Re: FBZ Polo's
I don't think there is a 5v channel in the door wiring harness. A simple 12v to usb should work, usb is 5v and gives about 1a of current. Some devices will even give you 2a of current.
firebulletz
Re: FBZ Polo's
Finally!
I will follow this guide: http://www.team-bhp.com/forum/diy-do-yo ... odule.html
I hope it will work[emoji23]Image
firebulletz
Re: FBZ Polo's
I managed to set everything except the remotes.
I did this: 09-cent. elect. -> adaptation - 10 -> remote control adaptation.
On "new value" i put "2" (i have 2 remotes), click "test" and after push the unlock button on two remotes, but they have not been recognized.
The bcm is compatible with 434mhz remotes?
I need your help [emoji21][emoji21]
