Page 3 of 3
Re: Seat Ibiza 6j Upgrading BCM and Auto light with CH/LH
Posted: Mon Jul 08, 2019 11:01 am
by ciclo
Skyscript wrote: Sun Jul 07, 2019 11:57 pm
I have no Ibiza SC. I checked ELSA and my wiring should be like this :
Left side :
T73b/12 --> T6d/6 RFL
Right side :
T73b/12 --> T6e/2 RFL
It's correct, I do not know why I thought your Ibiza is a SC.
Essentially it is the same, the fault is because there is no wire from the BCM T73b/12 to the reversing light/s.
Just checked the light switch and nothing is connected to T17/3. There was never anything connected with my knowledge.
With the old coding it also worked correctly.
I do not know what may be wrong with the electrical installation you did.
I think the BCM coding I provided is correct, comes from an Ibiza same like yours but with 'BCM Max' and automatic lights from factory.
Posted: Mon Jul 08, 2019 8:40 pm
by Skyscript
I will check my wiring again and respond when I've wired the tail lights. I hope I also find the cause for the fault in the Climatronic.
Hopefully i find the cause of the fault codes fast..
Posted: Sat Jul 13, 2019 10:43 am
by Skyscript
Hey,
Yesterday I managed to rewire the reverse light. Furthermore, I wired, installed and coded the new cruise control stalks.
All fault codes are now gone and everything works.
Also the climatronic fault code is gone, although I have changed nothing.
DRL was activated via the dipped beam only had to be re-coded.
So everything works now
Will make updates here if I retrofit something new.
Thank you for your help Ciclo.
Final Scan :
Samstag,13,Juli,2019,10:19:18:56266
VCDS -- Windows-basierter VAG/VAS-Emulator läuft auf Windows 7 x86
VCDS Version: PCI 18.9.1.0 HEX-V2 CB: 0.4505.4
Datenstand: 20190520 DS296.
Fahrzeug-Ident.-Nr.: VSSZZZ6JZER007887 KFZ-Kennzeichen: MICHAEL
Kilometerstand: 115560km Reparaturauftrag: AKTUELL
Fahrzeugtyp: 6J-SE25 (6N0)
Scan: 01 03 04 08 09 15 17 19 25 44 4B 56
Fahrzeug-Ident.-Nr.: VSSZZZ6JZER007887 Kilometerstand: 115560km
01-Motorelektronik -- Status: i.O. 0000
03-Bremsenelektronik -- Status: i.O. 0000
04-Lenkwinkelsensor -- Status: i.O. 0000
08-Klima-/Heizungsel. -- Status: i.O. 0000
09-Zentralelektrik -- Status: i.O. 0000
15-Airbag -- Status: i.O. 0000
17-Schalttafeleinsatz -- Status: i.O. 0000
19-Diagnoseinterface -- Status: i.O. 0000
25-Wegfahrsperre -- Status: i.O. 0000
44-Lenkhilfe -- Status: i.O. 0000
4B-Multifunktionsstg. -- Status: i.O. 0000
56-Radio -- Status: i.O. 0000
Adresse 01: Motorelektronik (J623-CBZB) Labeldatei:. DRV\03F-906-070-CBZ.clb
Teilenummer SW: 03F 906 070 GR HW: 03F 907 309 AE
Bauteil: SIMOS10.22AH10 5485
Revision: --H10--- Seriennummer:
Codierung: 001100D6202400080000
Betriebsnr.: WSC 00049 770 00143
ASAM Datensatz: EV_ECM12TFS02103F906070GR 004007
VCID: 78A81887725EF767A6D-802C
Kein(e) Fehlercode(s) gefunden.
Readiness: 0110 0101
Adresse 03: Bremsenelektronik (J104) Labeldatei:. DRV\6R0-907-37x-ESP90.clb
Teilenummer SW: 6R0 907 379 AS HW: 6R0 907 379 AS
Bauteil: ESP9.0i front H02 0002
Seriennummer: --------------
Codierung: 11DD287D212300C7881C1471845800480905
ASAM Datensatz: EV_Brake1ESP90iBOSCH 003020
VCID: 0F7A435B67D0D0DF177-805A
Adresse 04: Lenkwinkelsensor (G085) Labeldatei:* DRV\6R0-959-654.clb
Teilenummer SW: 6R0 959 654 HW: 6R0 959 654
Bauteil: LENKW.SENSOR H07 0070
Seriennummer: 29051304651073
Codierung: 01
Betriebsnr.: WSC 00000 000 00000
ASAM Datensatz: EV_LWSKLOVW25X 005001
ROD: EV_LWSKLOVW25X.rod
VCID: 7EA40E9F507AC957EC1-802A
Adresse 08: Klima-/Heizungsel. (J255) Labeldatei: 6R0-907-044.clb
Teilenummer SW: 6J0 820 043 E HW: 6J0 820 043 E
Bauteil: Climatronic H03 0808
Revision: S0000000
VCID: 261406FFE8EAB197C41-8072
Adresse 09: Zentralelektrik (J519) Labeldatei:. DRV\7H0-937-08x-09.clb
Teilenummer SW: 7H0 937 090 B HW: 7H0 937 090
Bauteil: BCM PQ25 Max4 H74 0712
Revision: B9074001 Seriennummer: 0571 341130505
Codierung: 7A8829E8A861010001200EF07E8B9FD80FC063A9608C2005200000020000
Betriebsnr.: WSC 12345 123 123456
VCID: 2D06F9D3CD1C82CF05B-8078
Subsystem 1 - Teilenummer: 1K0 955 559 AH Labeldatei: DRV\1K0-955-559-AG.CLB
Bauteil: RLS 210311 05 54 0403
Codierung: 07302D
Subsystem 2 - Teilenummer SW: 6R0 959 801 AJ HW: 6R0 959 801 AJ Labeldatei: 6R0-959-801.CLB
Bauteil: J386__TSG_FT 006 5110
Seriennummer: 12202557130528011642
Codierung: 020000
Subsystem 3 - Teilenummer SW: 6R0 959 802 AQ HW: 6R0 959 802 AQ Labeldatei: 6R0-959-802.CLB
Bauteil: J387__TSG_BT 006 5110
Seriennummer: 12202560130528060752
Codierung: 020000
Adresse 15: Airbag (J234) Labeldatei:| DRV\5K0-959-655.clb
Teilenummer SW: 6R0 959 655 K HW: 6R0 959 655 K
Bauteil: VW10AirbagA09 H10 0020
Revision: -------- Seriennummer: 003GX01R7U4Z
Codierung: 003039
Betriebsnr.: WSC 00049 770 00111
ASAM Datensatz: EV_AirbaVW10BPAVW250 A01001
ROD: EV_AirbaVW10BPAVW250.rod
VCID: 4ACC924F5C32B5F7009-801E
Crashsensor für Seitenairbag Fahrerseite:
Seriennummer: 3495RRB400250GJ2OPQ.
Crashsensor für Seitenairbag Beifahrerseite:
Seriennummer: 3505RRB401650HHORH3R
Adresse 17: Schalttafeleinsatz (J285) Labeldatei:| DRV\5K0-920-xxx-17.clb-SRI1
Teilenummer SW: 6J0 920 806 K HW: 6J0 920 806 K
Bauteil: KOMBI H01 0709
Seriennummer: 00000000000000
Codierung: 110E01
ASAM Datensatz: EV_Kombi_UDS_VDD_RM09 A04723
ROD: EV_Kombi_UDS_VDD_RM09_SK46.rod
VCID: 3430ECB72EB6D3074A5-8060
Adresse 19: Diagnoseinterface (J533) Labeldatei:. DRV\6N0-909-901-6R.clb
Teilenummer SW: 6N0 909 901 HW: 7H0 937 090
Bauteil: GW-K-CAN TP20 H74 0712
Revision: B9074001
Codierung: 022200
VCID: 70B820A71AAEAF276ED-8024
Adresse 25: Wegfahrsperre (J334) Labeldatei:| DRV\5K0-920-xxx-25.clb
Teilenummer SW: 5K0 953 234 HW: 5K0 953 234
Bauteil: IMMO H01 0709
Seriennummer:
Codierung: 000000
ASAM Datensatz: EV_Immo_UDS_VDD_RM09 A03710
ROD: EV_Immo_UDS_VDD_RM09.rod
VCID: 6A8C32CF3CF255F7209-803E
Adresse 44: Lenkhilfe Labeldatei: DRV\6Q0-423-156.clb
Teilenummer: 6R0 423 156 C
Bauteil: LenkhilfeTRW V278
Codierung: 11211
VCID: 3038E0A7D36EEF272ED-8064
Adresse 4B: Multifunktionsstg. Labeldatei: DRV\6J0-959-441.clb
Teilenummer: 6J0 959 441 A
Bauteil: MF-Modul 0007 0001
Codierung: 0000002
Betriebsnr.: WSC 77005 000 00000
VCID: 313EE5A3DD24E62F213-8064
Adresse 56: Radio (J503) Labeldatei:. DRV\5M0-035-1xx-56.clb
Teilenummer SW: 6J0 035 156 HW: 6J0 035 156
Bauteil: Radio H07 0012
Revision: R0000000 Seriennummer: SEZAZ1N6256030
Codierung: 010004080203
VCID: 64905CF7DE5603871A5-8030
Ende--------(Dauer: 01:03, Batt.-Spannung Start/Ende: 12.4V/12.4V)---------
Posted: Wed Jul 24, 2019 4:36 am
by ciclo
Excellent Skyscript!
Danke for the final report, autoscan, ... Perfekt !!!!!
With the same BCM coding I provided you, except DRLs coding (disabled), and CH/LH through foglights.
I guess your Ibiza didn't have the T17/3 wire for DRLs due to the type of Original light switch. It is just a thought.
Details as exhaustive as this are difficult to know within the immense amount of volkswangen vehicles for PQ25 platform around the world.
Posted: Mon Oct 12, 2020 2:27 pm
by MIH11MI6
Hi ciclo,
great work helping with this retrofit!
I previously had a Seat Ibiza 6J 1.2tdi CR Ecomotiv with Rain sensor, Auto lights and all (BCM 88). I completed an engine swap (2.0tdi) which forced me to revert to BCM 87. I have since then retrofitted the rain sensor, anti dazzle mirror.
I have a BCM 88 sitting here from my previous wiring system that I am looking to retrofit in. (BCM87D - BCM88D) to gain the auto light and CH/LH functionality again. I am hoping to follow this thread to complete this retrofit however I have an open point I was hoping you may be able to answer for me.
I have a set of custom built headlights, with Daytime running lights that run off the normal side light circuit. I used to have it so when CH/LH was activated at night, the side lights would come on, but I would also like the side lights to be on with ignition, when the light switch is set to the "AUTO" position. is this possible with an 88D BCM setup?
If you require any further info please let me know, I plan to begin the retrofit in the next couple days so will be able to get auto scans for you from VCDS if need be.
thanks
Matt
Posted: Fri Jan 08, 2021 1:13 am
by mustii_93
ciclo wrote: Thu Jun 20, 2019 2:28 am
BCM Max 7H0937090B
new coding
7A8829E88861010001200EF07ECB9FD80F4063A9608C2049200000020000
1
If with the new BCM coding the problem of the dimmer (E20) is not solved you'll have to change the terminal from T73b/4 to T73b/1 to feed the 58d signal. (same new coding)
2
It is possible that according to your personal tastes or installed bulbs (LEDs, etc) you want to change some behavior of the lights (DRLs, or others), so the new coding can be modified.
Post a new Autoscan with the new BCM and RLS codings (for future readers/users). With a little luck, all units will be OK.
Hey Ciclo! Read alot of your very detailed posts so first of all thanks for that. I have an Ibiza 6J with the rain/light sensor from factory.
I got the light switch with the AUTO function and found some instructions on the internet (see below) on how to connect everything
Lightswitch connector:
- Green/white wire (city light? I dont know how to translate that) move from pin 16 to pin 13
- Create a loop betweet pin 12 and pin 16
- Add a cable from pin 12 to BCM T73a (black plug) pin 37
I did all of that and activated RSL in VCDS. All the lights work, the switch works fine I tested all the modes. Only thing not working is the automatic lights.
The rain/light sensor is active, i double checked in VCDS. Any tips on what to check or what to change? Do i need more wiring?
Posted: Fri Jan 08, 2021 6:41 am
by ciclo
Hello mustii_93
Please post a full autoscan so I can tell you what you need.
Posted: Fri Jan 08, 2021 7:46 pm
by mustii_93
ciclo wrote: Fri Jan 08, 2021 6:41 am
Hello mustii_93
Hey Ciclo, here you go!
Chassis Type: 6J-SE25 (6R0)
VIN: VSSZZZ6JZBR030705 Mileage: 244420km-151875miles
4B-Multifunc. Module -- Status: Malfunction 0010
69-Trailer -- Status: OK 0000
Address 01: Engine (J000-CFWA) Labels:. 03P-906-021-CFW.clb
Part No SW: 03P 906 021 AA HW: 03P 906 021 BC
Component: R3 1.2l TDI H06 9980
Revision: 12005001 Serial number: 00000000000000
Coding: 00114014032401080000
Shop #: WSC 58862 001 1048576
ASAM Dataset: EV_ECM12TDI03103P906021AA 001020
ROD: EV_ECM12TDI03103P906021AA.rod
VCID: 679E62C39E6320BCA3-8032
Readiness: 0 0 0 0 1
Address 03: ABS Brakes (J104) Labels:. 6R0-907-37x-ESP82.clb
Part No SW: 6R0 907 379 AJ HW: 6R0 907 379 AF
Revision: --------
Coding: 110224DB817000B2882C24E281D600521300
Shop #: WSC 04941 000 00000
VCID: 06404F47B529D9B438-8052
4 Faults Found:
02214 - Tire Pressure Warning
002 - Lower Limit Exceeded - Intermittent
Fault Status: 00100010
Fault Priority: 0
Fault Frequency: 10
Reset counter: 227
Mileage: 241256 km
Time Indication: 0
Date: 2015.05.13
Time: 15:11:16
Hex Value: 0x0000
Hex Value: 0x8000
Hex Value: 0x1203
Hex Value: 0x2BA9
Hex Value: 0x677E
Hex Value: 0x7F80
Hex Value: 0x7EF9
00526 - Brake Light Switch (F)
011 - Open Circuit - Intermittent
Fault Status: 00101011
Fault Priority: 0
Fault Frequency: 1
Reset counter: 249
Mileage: 0 km
Time Indication: 0
Date: 2015.05.31
Time: 20:12:52
Hex Value: 0x0007
Hex Value: 0x0002
Hex Value: 0x12B0
Hex Value: 0x04A0
Hex Value: 0x0082
Hex Value: 0x7F7F
Hex Value: 0x7FF9
01169 - Door Contact Switch Driver Side (F2)
Fault Status: 00100100
Fault Priority: 0
Fault Frequency: 1
Reset counter: 249
Mileage: 0 km
Time Indication: 0
Date: 2015.05.31
Time: 20:12:52
Hex Value: 0x0007
Hex Value: 0x0002
Hex Value: 0x12A5
Hex Value: 0x25A0
Hex Value: 0x0082
Hex Value: 0x7F7F
Hex Value: 0x7FF9
00532 - Supply Voltage B+
Fault Priority: 0
Fault Frequency: 1
Reset counter: 250
Mileage: 244379 km
Time Indication: 0
Date: 2015.06.01
Time: 19:20:53
Hex Value: 0x0007
Hex Value: 0x0000
Hex Value: 0x1016
Hex Value: 0x038C
Hex Value: 0x0F7C
Hex Value: 0x7E81
Hex Value: 0x7DF9
Part No SW: 6J0 820 043 B HW: 6J0 820 043 B
Component: Climatronic H07 0505
Revision: S0000000
VCID: 230636D322DB0C9C3F-8076
Part No SW: 6R0 937 088 B HW: 6R0 937 088
Component: BCM PQ25 Re4 H46 0321
Revision: BU046001 Serial number: 0328 176100005
Coding: 3A882BE8C8610100013005B07ECB9EC88F80600F7E8C0009200000000000
Shop #: WSC 17504 211 90855
VCID: 3D32E0ABA47F5A6C29-8068
Subsystem 1 - Part No: 1K0 955 559 AH Labels: 1K0-955-559-AG.CLB
Component: RLS 010710 05 54 0403
Coding: 03302D
Subsystem 2 - Part No SW: 6R0 959 801 N HW: 6R0 959 801 N Labels: 6R0-959-801.CLB
Component: J386__TSG_FT 003 3110
Coding: 420000
Subsystem 3 - Part No SW: 6R0 959 802 Q HW: 6R0 959 802 Q Labels: 6R0-959-802.CLB
Component: J387__TSG_BT 003 3110
Coding: 420000
Subsystem 4 - Part No SW: 6R0 959 811 D HW: 6R0 959 811 D
Component: J388__TSG_HL 002 3110
Subsystem 5 - Part No SW: 6R0 959 812 D HW: 6R0 959 812 D
Component: J389__TSG_HR 002 3110
Address 10: Park/Steer Assist (J446) Labels:| 6J0-919-475.clb
Part No SW: 6J0 919 475 B HW: 6J0 919 475 B
Component: PARKHILFE 4K H07 0008
Revision: -------- Serial number: 80321013900349
Coding: 010002
ASAM Dataset: EV_SE250ParkiAssis2 S01006
ROD: EV_SE250ParkiAssis2.rod
VCID: 3522F88B944F822CE1-8060
Component: VW10AirbagA09 H09 0020
Revision: -------- Serial number: 003GX003KD46
Coding: 003039
Shop #: WSC 06401 785 00200
VCID: 4AD8BB77EDB1FDD49C-801E
Serial number: 3495RRB404V6R0C240IM
Serial number: 3505RRB404T6R0C26OCW
Part No SW: 6J0 920 802 J HW: 6J0 920 802 J
Component: KOMBI H05 0404
Coding: 110800
Shop #: WSC 00046 000 00000
ASAM Dataset: EV_Kombi_UDS_VDD_RM09 A04086
ROD: EV_Kombi_UDS_VDD_RM09_SE25.rod
VCID: 2F2ECAE37613B8FCAB-807A
Address 19: CAN Gateway Labels:. 6R0-907-530-V1.clb
Part No SW: 6R0 907 530 B HW: 1K0 907 951
Component: J533 Gateway H28 0020
Revision: H28 Serial number: 230610F2001373
Coding: 7D0B5D00080000000202
VCID: 3228C397AD219514C4-8066
Component: IMMO H05 0404
Serial number:
Shop #: WSC 00000 000 00000
VCID: 6A981BF78D711DD4BC-803E
Address 44: Steering Assist Labels: None
VCID: 55E2580BA80FA22C01-8000
Address 4B: Multifunc. Module Labels: 6J0-959-441.clb
Part No: 6J0 959 441
Component: MF-Modul 0007 0001
Coding: 0000001
Shop #: WSC 77005 000 00000
VCID: 70AC099F63ADE704F2-8024
1 Fault Found:
00849 - S-contact at Ignition/Starter Switch (D)
Address 56: Radio
Cannot be reached
Address 61: Battery Regul. (J840) Labels:. 1K0-907-534.clb
Part No SW: 6R0 907 534 HW: 1K0 907 951
Component: Batt.regelung H28 0020
Coding: 0303185A
VCID: 74A4058FD7B5DB2416-8020
Component: J367-BDM H07 0125
Serial number: 00000000002790296796
Address 69: Trailer Labels: None
Part No SW: 5F0 05V 010 2 HW: 5F0 05V 010 2
Component: TOWBARMODULE ECS 0010
Coding: 0000001
VCID: 291A24FB80F7D6CC75-807C
End----------(Elapsed Time: 01:28, VBatt start/end: 12.1V/12.1V)-----------
Posted: Fri Jan 08, 2021 8:42 pm
by ciclo
Try this new BCM coding:
3A882BE8C8610100013007B07ECB9EC88F80600F7E8C2009200000000000
If that electrical installation that you show is adequate, the Automatic lights function should work without problems in your Ibiza 6J, in addition to the CH and LH functions.
Good luck!
ah ... check the tires pressure and confirm with the SET button (as indicated in the user manual), then clear all DTCs with the VCDS.
Posted: Fri Jan 08, 2021 10:16 pm
by mustii_93
ciclo wrote: Fri Jan 08, 2021 8:42 pm
LH functions.
Good luck!
You are great! It works. Thank you!
Is it possible to install Xenon lights with this BCM or do I need to change BCM?
And the other mod I wanted was heated seats.
Posted: Sat Jan 09, 2021 6:06 am
by ciclo
If I remember correctly, during the production process of Ibiza 6J different types of Xenon headlights were installed in it (maybe I'm wrong), and I also think I remember that one of the BCMs used for one of those Xenon headlight types is the BCM that you currently have installed. 6R0 937 088B (Re4).
Do a search on the net ... (Part No SW: 6R0 937 088 B HW: 6R0 937 088) ... maybe you will find some autoscan of a 6J with the xenon headlights installed, ... and the unit for the automatic headlight leveling.
I recommend that you contact iichel, he had a similar situation with his 6R "Bluemotion" ... and because I'm sure you will understand each other perfectly (NL).
The heated seats are highly recommended, it's a great upgrade.
Here is a link to the parts catalog in case you have to look for the parts you need, learn how to use it and everything will be fine for your upgrades.
viewtopic.php?p=466570#p466570
edit
Here is an example with a BCM 'F' later than model 'B' but in essence it is the same: (...with module/unit '55')
https://forums.ross-tech.com/index.php? ... ost-113148
Well, it's a very strange post, but it confirms my suspicions ...
By the way, I would have fixed that problem in 0,1 sec ... OEM way ... but I'm not registered on the ross-tech forum.
Posted: Fri Nov 19, 2021 7:31 am
by adamswiatek
Skyscript wrote: Thu May 16, 2019 9:47 pm
Hey guys,
I own a Seat ibiza 6j 1.2TSI from 2013, with :
-H7 Halogen lights
-Heated Seats
-fog lights
-Headlight washers
-automatic air conditioning
ect.
Unfortunately without Auto Light with CH/LH and rain sensor.
My plan was to retrofit the rain / light sensor on the glass and then to activate the automatic light.
I already mounted the rain / light sensor on the glass and wired it.
On the way there I found out that my BCM (6R0937087P)only supports the rain function, so i bought the 7H0937090B.
After switching and coding the BCM i noticed that there is no turning Signal, no light in the instrument cluster and the windows, radio key are not working.
I read a lot in this forum, especially from ciclo and figured out that i have maybe to connect Pin 28 and 29 from the Instrument cluster with the BCM 54/57 Pins is this correct ?
Furthermore, I need help to get the Auto light with CH/LH wiring.
would be nice if someone could help me.
Thanks in advance and I'm sorry for any mistakes.
Hello Skyscript
Did you finally made this upgrade?
I bought Seat Ibiza 2013 for my daughter and this car dosnt have Auto Lights and sensors, and unfortunatelly BCM 6R0 937 087 M.
I would like to make this same upgrade, but it looks very difficult to realise.
Would you be able to help me go trought this?
Thank you
Adam
Posted: Mon Nov 22, 2021 8:42 pm
by KamilPL
adamswiatek wrote: Fri Nov 19, 2021 7:31 am
Hey guys,
-H7 Halogen lights
-Heated Seats
-fog lights
-Headlight washers
ect.
Hello Skyscript
Thank you
Adam
Adamie, napiszcie do mnie ty bądź twoja córka co użytkuje auto postaram się pomóc
jestem z Polski i zmieniłem bcm z 6R0937087K (high) na 7h0937090 (max) + włącznik świateł z funkcją auto, czujnik deszczu/zmierzchu
https://www.facebook.com/kamil.pomorski.35
