Franciswat's Polo 6R 1.6 Bifuel
Re: Franciswat's Polo 6R 1.6 Bifuel
Maybe and with great care you can remove that small wrinkle with a steamer, in which case you must also take into account the level of dirt on the entire roof. :)
Franciswat
Drives: 6R 1.6 Bifuel
Post by Franciswat »
thank u for the suggestion I like it.
I'm just a bit worried heat may compromise the glue . this roofs are not so good. I was thinking to try first by adding something behind the crack to increase the tension. what do you think mate? :wink:
I don't know, many ideas can come up to fix it and any one of them can be catastrophic... and you will be forced to buy a new roof.
I agree with you regarding the quality of the materials after a certain amount of time. Many peeled roofs can be seen...
Perhaps it is best to do nothing, time and environmental situations can cure it. :lol:
Franciswat
ciclo wrote: Sun Aug 09, 2020 8:44 pm Perhaps it is best to do nothing, time and environmental situations can cure it. :lol:
That's true, I will wait sometime and see if time can fix it. :D
Thanks Fernando.
Today I retrofitted my new Composition Media MIB2 PQ.
Looks like my car doesn't like It. :roll:
It's not impossible to code Radio with 56-Radio, I think It's now in 5F-Information Electr.
My idea is now to untick Radio in Gateway list and tick 5F-Information Electr.
The major issue is volume which randomly works. I think it can be fixed with proper coding.
I'll try tomorrow. Hope no need to add a gateway.
Monday,10,August,2020,20:34:11:39744
VCDS -- Windows Based VAG/VAS Emulator Running on Windows 7 x64
VCDS Version: 17.1.3.0 (x64)
Data version: 20170203 DS267.2
www.Ross-Tech.com
VIN: WVWZZZ6RZCY540000   License Plate:
Chassis Type: 6R (7E0)
Scan: 01 03 04 08 09 10 15 17 19 25 44 55 56 5F 77 0B
VIN: WVWZZZ6RZCY540000   Mileage: 108200km-67232miles
56-Radio -- Status: OK 0000
5F-Information Electr. -- Status: Not registered 0011
61-Battery Regul. -- Status: Malfunction 0010
77-Telephone -- Status: Not registered 0001
Address 01: Engine
Cannot be reached
Address 03: ABS Brakes (J104)       Labels: 6R0-907-37x-ESP82.clb
   Part No SW: 6R0 907 379 BC    HW: 6R0 907 379 AF
   Component: ESP8.2i front H05 0002
   Revision: --------
   Coding: 210228E3217100B5842514E484D700401300
   Shop #: WSC 00788 648 00255
   VCID: 00085B4297984341E9-8054
   Part No SW: 6R0 907 044 H    HW: 6R0 907 044 H
   Component: Climatronic   H12 0812
   Revision: V0000000
   VCID: 3878F3A28BC8CB8111-806C
Address 09: Cent. Elect. (J519)       Labels: 7E0-937-BCM-V1.clb
   Revision: B9080001    Serial number: 0771 060161479
   Coding: 3CB02BB808E1240093380E916CEB0FD9DAC0672F608D30D1200000030000
   Shop #: WSC 02737 534 00190
   VCID: 68D863E29BE89B0141-803C
   Subsystem 1 - Part No: 5K7 955 559 B  Labels: 5K7-955-559.CLB
   Component: RLS 080515 03  37  0059
   Coding: 0228DD
   Subsystem 2 - Part No SW: 6R0 959 801 AB    HW: 6R0 959 801 AB  Labels: 6R0-959-801.CLB
   Component: J386__TSG_FT  008 1611
   Serial number: KU0KU004011200011991
   Coding: 18BC30
   Subsystem 3 - Part No SW: 6R0 959 802 AD    HW: 6R0 959 802 AD  Labels: 6R0-959-802.CLB
   Component: J387__TSG_BT  008 1611
   Serial number: KU0KU005011200017885
   Coding: 08BC30
   Subsystem 5 - Part No: 1K0 951 605 F
   Component: LIN BACKUP HO  H01 0008
   Subsystem 8 - Part No SW: 6R0 959 811 G    HW: 6R0 959 811 G
   Component: J388__TSG_HL  008 1611
   Serial number: KU0KU010011200012406
   Coding: 08BC32
   Subsystem 9 - Part No SW: 6R0 959 812 G    HW: 6R0 959 812 G
   Component: J389__TSG_HR  008 1611
   Serial number: KU0KU009011200013136
   Coding: 08BC32
Address 10: Park/Steer Assist (J446)       Labels: 7E0-919-475.clb
   Part No SW: 7E0 919 475 L    HW: 56D 919 475
   Component: PARKHILFE 8K  H02 0106
   Revision: --------    Serial number: 20231629400567
   Coding: 108001
   Shop #: WSC 12345 123 12345
   ASAM Dataset: EV_VW75XParaKssis8K 001003
   ROD: N/A
   VCID: 3B72ECAEB2FEE099FC-806E
No ASAM data for: "EV_VW75XParaKssis8K" (VW25)
   Component: VW10Airbag022 H09 0020
   Revision: --------    Serial number: 003GX011W0JJ
   Coding: 003232
   ASAM Dataset: EV_AirbaV1W0BPAVW250 A01001
   ROD: N/A
   VCID: 4A9CB96AED24491177-801E
   Subsystem 1 - Serial number: 3575HRB4059124B2F99H
   Subsystem 2 - Serial number: 3585HRB4061131GQCOUS
   Subsystem 3 - Serial number: 3515RRB405P0VC0I5P0W
   Subsystem 4 - Serial number: 3525RRB40510VC0IA9B9
No ASAM data for: "EV_AirbaV1W0BPAVW250" (VW25)
   Part No SW: 6R0 920 871 A    HW: 6R0 920 871 A
   Component: KOMBI         H03 0505
   Coding: 140E00
   ASAM Dataset: EV_Kombi_UDS_VDD_RM09 A04113
   VCID: 3460C7929FA02FE13D-8060
   Revision: B9080001
   Coding: 002200
1 Fault Found:
            000 -  -
                    Fault Status: 01100000
                    Fault Priority: 2
                    Fault Frequency: 2
                    Reset counter: 255
                    Mileage: 108202 km
                    Time Indication: 0
                    Date: 2015.01.01
                    Time: 02:15:35
   Component: IMMO          H03 0505
   Serial number:
   Shop #: WSC 00000 000 00000
   ASAM Dataset: EV_Immo_UDS_VDDR_M09 A03009
   ROD: N/A
   VCID: 6ADC19EA8DE4A91157-803E
No ASAM data for: "EV_Immo_UDS_VDDR_M09" (VW36 *)
   Part No: 6R0 423 156 B
   Coding: 11250
   Shop #: WSC 00788
   VCID: 2F6AC8FEEA860C3940-807A
Address 55: Headlight Range (J431)       Labels: 6R0-907-357.clb
   Revision: --------    Serial number: --------------
   Coding: 0110000001000000
   ASAM Dataset: EV_HeadlReuglVWLWRPt 001004
   ROD: N/A
   VCID: 77FA309ECE5604F9D8-8022
No ASAM data for: "EV_HeadlReuglVWLWRPt" (VW25)
Address 56: Radio
Cannot be reached
Address 5F: Information Electr. (J794)       Labels: None
   Part No SW: 5K7 035 200 K    HW: 5K7 035 200 K
   Component: MU-S-D-ER     H41 0449
   Serial number: VWZAZ2T5211382
   Coding: 02230500AA0000001111110300880A001F0100D40020010003
   Shop #: WSC 00066 790 00451
   ASAM Dataset: EV_MUStd4CTAST 001022
   ROD: N/A
   VCID: 2C50DFF24790772165-8078
No ASAM data for: "EV_MUStd4CTAST" (VW25)
4 Faults Found:
1562 - ROD - Unknown Error Code
          - 00 [009]
                    Fault Status: 00000001
                    Fault Priority: 4
                    Fault Frequency: 1
                    Reset counter: 21
                    Mileage: 108202 km
                    Date: 2020.08.10
                    Time: 02:15:34
7169 - ROD - Unknown Error Code
          - 00 [009]
                    Fault Priority: 6
                    Fault Frequency: 1
                    Reset counter: 21
                    Mileage: 108202 km
                    Date: 2020.08.10
                    Time: 02:15:36
7194 - ROD - Unknown Error Code
          - 00 [009]
                    Fault Priority: 6
                    Fault Frequency: 1
                    Reset counter: 21
                    Mileage: 108202 km
                    Date: 2020.08.10
                    Time: 02:15:36
0001 - ROD - Unknown Error Code
          - 00 [009]
                    Fault Priority: 6
                    Fault Frequency: 1
                    Reset counter: 21
                    Mileage: 108202 km
                    Date: 2020.08.10
                    Time: 02:15:34
Address 77: Telephone
Cannot be reached
End-------------------------(Elapsed Time: 03:39)--------------------------
Franciswat
After many troubles radio works fine.
Still got "open circuit error" for the Antenna, probably because I'm using an adaptor female twin -> male single (don't have diversity sound system).
I ordered a new adaptor so I can see If something change. :wink:
patil
Post by patil »
Hello franciswat!
For correct operation of your composition media:
You should disable(deselect) address 56 in gateway installation list and enable (select) address 5F and address 77.
Franciswat
Hi Patil, thanks for the info. :D
Have you installed a CM/DM?
This is my radio startup!
https://youtu.be/yjb7JuEbwo8
Today a package arrived! :D
patil
Post by patil »
Franciswat wrote: Fri Aug 14, 2020 8:50 pm Hi Parole, thanks for the info. :D
Nice composition media👌
I have installed Discover media software unlocked version.
Good luck with your new side assist retrofit👍
Franciswat
Nice radio Patil! I'm experimenting a slow startup with radio logos.
Do you have same issue with your DM?
patil
Post by patil »
Franciswat wrote: Sun Aug 16, 2020 2:01 pm Nice radio Patil! I'm experimenting a slow startup with radio logos.
Have you loaded radio logo's manually or they are automatically loading from broadcasting radio stations?
I have loaded logo's manually and they instantly load.
Franciswat
patil wrote: Sun Aug 16, 2020 2:24 pm
Logos were loaded automatically, I just manually added few missing one.
I'll try to delete al of them and add manually, thanks. :D
Franciswat
MIB2 PQ Composition Media with DAB+ and APP button
Software unlocked with Voice commands and Smartphone connectivity activated
New connectors, from left: quadlock, aux, FM, DAB
New quadlock connector
USB/aux wiring (glovebox)
USB/aux plug
FM radio
DAB radio
MFA+
Excellent!👌 Good pics. 8)
Enjoy it Francesco!
I guess in Italy the hazard lights button is used a lot. :mrgreen:
(as in many other places :lol:)
benzinkopf
Drives: 1.2TSI 105HP DSG7
Post by benzinkopf »
i just cant laugh without posting here. [emoji23]ciclo’s eyes really sharp.
RobertVW
Drives: T6
Post by RobertVW »
Franciswat wrote:Hi Patil, thanks for the info. :D
May I ask why 7E0 radars and not 5Q0?
Wysłane z mojego SM-G973F przy użyciu Tapatalka
