So, have you modified your IC eeprom? How?CNK wrote:It is possible to set in the eeprom, but this is dependent on the ECU controller.ciclo wrote:Cruise control speed on MFD? therefore... Cruise Control Display (High CCS according ODIS)? hehe...I also want it, ...if this would be possible.
I have enabled this, but this doesn't work on my 1.4 85ps ECU from 2011. I know people with Golf MK5 who changed the ECU for newest to make it work.. (with Scirocco '15 instrument cluster).
But I can't found any information about ECU to engine in my 6R..
Tadej's 6R Polo 1.6TDI DSG
Re: Tadej's 6R Polo 1.6TDI DSG
- CNK
- Drives: 6R
No, not me. Check your emailciclo wrote:So, have you modified your IC eeprom? How?
When I changed my instrument cluster, I had warning light of washer fluid sensor, and my acquaintance disabled this option in my IC (because I don't have this sensor yet).
He tried to enable speed on display, but this don't work in my 6R.
So maybe Polo 6R WRC has other engine controller. But for now, I have only 1.4 85ps..
True, but the washer fluid sensor light is simply a VCDS setting. Modifying the EEPROM is not so easy
- CNK
- Drives: 6R
Yeap, but in VCDS some things can't be change, for example "needle sweep" in some ICs can't be enabled..iichel wrote:True, but the washer fluid sensor light is simply a VCDS setting. Modifying the EEPROM is not so easy
But it is possible by eeprom. In this way I had "staging" on my old 6R0920860H IC
tadej
- Drives: 6R 1.6TDI DSG
Just a little update.
I sold my Polo to new owner(for his wife), he called me in less than 24 hours a few times to thank me, that car is really great.
In the next few hours I'm taking delivery of VW Golf 2.0TDI DSG Highline, all spec up
from Vienna leather, bi-xenon, ACC, panoramic sunroof, webasto, LED tail lights, oryx white color, Durban ALU wheels, Discover PRO,...
Will post a few pictures of my new ride
that sounds like a very nice car! congratulations
Frozenmidget
- Drives: 6R 2011
Hello tadej! Im a new member so i cant send you a message about My question, hope you can help me. So i bought the U-Tube headlights from that x2car website and i they look and fit Well, the Only issue i have is that i think they are not bright enough in the lower beam.. Do you also notice that? I have Philips Xtreme vision with 130%more light. Thanks!tadej wrote:Just a little update.
In the next few hours I'm taking delivery of VW Golf 2.0TDI DSG Highline, all spec upfrom Vienna leather, bi-xenon, ACC, panoramic sunroof, webasto, LED tail lights, oryx white color, Durban ALU wheels, Discover PRO,...
Greetings Emir
