[phpBB Debug] PHP Warning: in file [ROOT]/ext/cleantalk/antispam/model/CleantalkSFW.php on line 184: Undefined array key 1 UK-POLOS.NET - THE VW Polo Forum • Tadej's 6R Polo 1.6TDI DSG - Page 6
ciclo wrote:Cruise control speed on MFD? therefore... Cruise Control Display (High CCS according ODIS)? hehe...I also want it, ...if this would be possible.
It is possible to set in the eeprom, but this is dependent on the ECU controller.
I have enabled this, but this doesn't work on my 1.4 85ps ECU from 2011. I know people with Golf MK5 who changed the ECU for newest to make it work.. (with Scirocco '15 instrument cluster).
But I can't found any information about ECU to engine in my 6R..
So, have you modified your IC eeprom? How?
Re: Tadej's 6R Polo 1.6TDI DSG
Posted: Wed May 04, 2016 7:34 am
by CNK
ciclo wrote:So, have you modified your IC eeprom? How?
No, not me. Check your email
When I changed my instrument cluster, I had warning light of washer fluid sensor, and my acquaintance disabled this option in my IC (because I don't have this sensor yet).
He tried to enable speed on display, but this don't work in my 6R.
So maybe Polo 6R WRC has other engine controller. But for now, I have only 1.4 85ps..
Posted: Wed May 04, 2016 9:17 am
by iichel
True, but the washer fluid sensor light is simply a VCDS setting. Modifying the EEPROM is not so easy
Posted: Wed May 04, 2016 10:26 am
by CNK
iichel wrote:True, but the washer fluid sensor light is simply a VCDS setting. Modifying the EEPROM is not so easy
Yeap, but in VCDS some things can't be change, for example "needle sweep" in some ICs can't be enabled..
But it is possible by eeprom. In this way I had "staging" on my old 6R0920860H IC
Posted: Fri Sep 09, 2016 10:31 am
by tadej
Just a little update.
I sold my Polo to new owner(for his wife), he called me in less than 24 hours a few times to thank me, that car is really great.
In the next few hours I'm taking delivery of VW Golf 2.0TDI DSG Highline, all spec up from Vienna leather, bi-xenon, ACC, panoramic sunroof, webasto, LED tail lights, oryx white color, Durban ALU wheels, Discover PRO,...
Will post a few pictures of my new ride
Posted: Thu Sep 15, 2016 5:04 pm
by iichel
that sounds like a very nice car! congratulations
Posted: Sat Oct 01, 2016 3:55 pm
by Frozenmidget
tadej wrote:Just a little update.
Hello tadej! Im a new member so i cant send you a message about My question, hope you can help me. So i bought the U-Tube headlights from that x2car website and i they look and fit Well, the Only issue i have is that i think they are not bright enough in the lower beam.. Do you also notice that? I have Philips Xtreme vision with 130%more light. Thanks!
Greetings Emir
