Hi all again, long time no speak.
I am nearing the final stages of my AWD 6J build, painting in a couple of weeks.
In the meantime I had the cabin stripped down and used it as an opportunity to tidy up the auto lights retrofit completed at the end of last year.
I ran a full test on all functions of once the loom got put back in and noticed that the auto lights are not working (dipped and full beam not turning on when in auto mode)
- I have the coming home lights/ leaving home lights set to dipped beam and they come on.
- I put the light sensor in a sealed box plugged in, ensuring it was dark enough and it did trigger.
- I also did an output test on the dipped beam from the BCM and they switched on individually perfectly fine.
I have attached an image of the long coding, best I could do without VCDS to hand at my new workshop, I plan on getting it soon.
@iichel or @ciclo looking at the long coding, can you see anything obvious as to why the auto lights aren't working even though all output tests work?
I thought it could potentially be because the engine wasn't running? but I didn't think that was the behaviour of the auto lights.
Headlight level switch also isn't working, but that's probably just me made a mistake so will be running through that tomorrow.
I know there is a rain and light recognition sensor fault, but it works for coming home/leaving home lights and they only switch on when the RLS is in a closed box (best way to simulate darkness)
Thanks!
