Joe's Gti Progress Thread- Leaky
joe2612
Location: Guildford, Surrey, Drives: Polo GTI 6n2 Black
Re: Joe's 3rd Gti Progress Thread
Post by joe2612 »
Pics will be up soon guys- been tied down with trying to sort this front end low speed clonk coming front the front coilovers.
( and now the rotational wheel squeak i developed about 10 minutes ago :| )
joe2612
Post by joe2612 »
Took a few ones at work : gives a general idea on stance. Need to go down abit on the rear though. :wink:
joe2612
Post by joe2612 »
The finished article, wheels:
Godderz23
Post by Godderz23 »
Wheels have polished up really nice dude. Ride heights looking good also. :-D
6N2 GTI 00
Post by 6N2 GTI 00 »
Looks very smart Joe :) Top job on the wheels too they have come up really well
I would say your plenty low enough at the moment, you dont want to go too low otherwise you will loose the performance benefits of the coilovers. What other updates can we expect next then?
joe2612
Post by joe2612 »
yeah i think im just at the limit of it being semi-practical..
Update wise there won't be much till June, as im off to Thailand for 6 weeks next week..
However i will update once i've fixed this BLOODY front coilover knocking noise, took off and re fittied for the sixth time this evening. Starting to think its either the bumpstops somehow. Alex mentioned the Wishbone bushes- but no play or degredation sign in them.
Was supoosed to get it all tracked properly tommorow morning- but cancelled that as i can see myself taking the whole suspension set-up apart soon enough. hmpph!
6N2 GTI 00
6 weeks in Thailand sounds immense!
Sounds like one of those annoying little noises that are hard to put right, mine is still creaking on the drivers side rear but its bareable at the moment. I pressume your pretty close to the lowering limit on the front?
Take pics and post it up as you install mate - I might be able to spot whats wrong
Describe the sound to me again
BIG RHYS
Post by BIG RHYS »
Mine does this look at you drive shaft hitting the chassis
joe2612
Post by joe2612 »
Videos and pics on route..
BIG RHYS
Post by BIG RHYS »
I will try and get some pic's up joe
joe2612
Post by joe2612 »
Funninly enough, since removing and refitting this eve, the drivers side has become even noisier, even though last week it was quieter than before after the 5th refit.. it seems the noise changes in volume everytime i refit..
Heres some pics of the assembly, i've tighten the top nut on wuntil it gets tight. I then tighten the rest once its on the car. It gets to a point where the rubber twists if i try to tighten the nut any further..
Definitely not anything hitting anything as i've been FAR lower than i am now, with no problems whatsoever.
Heres a video recorded in the drivers wheel arch while i rock the car from side to side, up and down, you can quite clearly here the noise.
http://s270.photobucket.com/albums/jj88 ... M_0197.mp4
Oh and here's a better wheel pic:
joe2612
Post by joe2612 »
Re: Joe's 3rd Gti Progress Thread- Knocking Noise Vid Inside
So are we talking about the squeak or otherwise?
The pics look correct. The top mount looks ok, albeit worn. Id possibly look to replacing those and the axial groove bearing rings that sit inside
joe2612
Post by joe2612 »
Yes that noise as such in the video. I refitted both coilovers with new topmount bearings and cups aswel over the W/E; which made no difference at all. Interestingly when i de-greased and greased the main shock piston it did mute the noise some what :?
May be down to knackered shocks- although they still perform brilliantly and don't show the usual traits of a knackered shock..
