Starting/Running Problems on 1.3CL...
Karl_CLCoupe
I came to my car at 1:30 this morning after doing a spot of taxi-ing for friends, and the car was a bit more hesitant than normal to start. When the engine did come into life, it idled very low (no idea of exact revs, as have no rev counter), but as a means of comparison I turned main beam on, and they were very dull, yet when I applied a little gas, car ran well, lights were at full brightness. I then backed off the gas to see whether the car had sorted itself, and the car cut-out.
Started it once again with hesitance, and similar happened. I gave it some gas, and same results as before, only I proceeded to drive, thinking giving it a bit of a run might sort it. Pulled up after 30 mins and the engine was at temperature. It started exactly as normal, with no hesitance, and revs were normal.
Could this be linked to other episods were the car has been started from warm, the engine has then gained some revs of its own accord, then settles back to 'normal' idle?
Thanks.
Karl.
Thanks.
Karl.
GroovyCarrot
- Sponsor
The lights dimming is perfectly normal if the car's revving very low (mine dim below around 950rpm), as the alternator isn't putting out enough power so they have to draw from the battery instead - obviously it'll be worse if your battery's a bit knackered.
Fraid I can't really offer any advice as to why it's stalling though, I know nowt about fuel injection.. although from what I can see, the blue temp sender seems to be the cause of a lot of these sort of problems
GroovyCarrot
- Sponsor
Tahrey1043
dunno mate never had too much problems with cold running on mine without hot air pipe, 100% functional temp sensor OR working thermostat (ie engine started bloody freezing and stayed that way)
well ok, there were problems, it might clonk onto 3 cylinders for a bit, idle a bit low if you clutch down after a run, or be a little lumpy and hesitant after just starting out, but not giving symptoms quite like that - low revs from the get-go, cutting out etc. did you run the starter for *just* long enough to get the engine going, or have it overrun slightly?
besides it aint *that* cold - not freezing, is it..
- bstardchild
- Moderator
http://www.tigerstyle.co.uk/poloforum/v ... php?t=9659Tahrey1043 wrote:besides it aint *that* cold - not freezing, is it..
Tahrey1043
clever stuff! that explains things
maybe forgetting to re-fit the exhaust manifold pipe *helps* with the running in such situations? (similar to the situation you described with the intake behind the radiator)
riiiiiiight!Like when you breathe closely to your heat exchanger at the back of your fridge, as you do.
Tahrey1043
how badly is it overheating?
i'd put that down to the thermostat and/or radiator/fan (or maybe a general lack of coolant!) myself mate. the temp sensor is basically for telling the ECU how hot the engine is so it can adjust the fuel mixture accordingly.
i.e. mine was blitzing 95-RON like it was going out of fashion (30mpg on a 1-litre - granted it had a hard life, but that included a lot of motorway work) and occasionally running a little... "funny" (just slow to respond) til i got those two sorted out - always a little "on the choke" as it rarely got above 70'c (normal running temp, about 85'c), and compounding it, when the sensor played up, it overfuelled even more, causing the response problem.
