ISO connections on 9n
Posted: Wed Feb 16, 2005 2:13 pm
Does anyone have a diagram or details for the ISO connectors on the polo 9n. I've heard VW use some of the pins in a non standard way.
I think they must have some kind of speed or maybe a CAN bus cable in there because the original VW radios have a feature called GALA, which adjusts the volume according to the speed of the car.
I've been informed by pioneer that the while/purple cable in the ISO harness on a polo manual can be used to detect speed pulses. Anyone know which pin this is?
Also, I read somewhere in this forum that I should swap the red and yellow cables around. I havent done this yet, but the headunit I've just installed seem to power up and down fine - the only problem is when I start the engine, it cuts power to the radio for a second or so, will this probably be solved by switching them?
