well this summer i will be redoing the ice so i need you
Posted: Sun Jun 08, 2003 6:19 pm
ok ill start with my spec now and then ill tell you what i want, then my ideas and then i really need your help deciding what to do
i am planning to redo the boot as at the moment its reasonably punchy but when you really want it to stop your heart theres not enough sub bass to satisfy i.e. with a dance track i can easily push the beat at silly volumes but on garage music or test tones below about 80Hz theres not enough
so...
at the moment on the bass front i have 2 10" sony X-plods running off a sony X-plod amp but theese are the early ones so they dont push as hard as you would expect for the power they take
and then... and den...and den...and den... and den...
im thinking off adding some larger subs but since i have a huge sub box and a 5 door this means completely re doing the boot, id like to get a reasonably stealth look so that if i want all you see is black carpet at a higher leval than normal but so that i can also have a bit of show
i dont want to get into the realms of 2 ohm 2000w twin voice coil and class D mono block amps but i am willing to put a little money into it ( im flexible but not rich
my ideas are as follows
2x 10" and a pair of 12" or 15" each pair running of a 2 channel amp and i will be rewiring with 0 gauge and keeping my power cap which is rated at 1 farad but i can still get dancing lights so i may double it upnow the problem is i have pout out feelers for my sub box "as is" and theres not been much interest so if i could i might re use the components (amp, subs)
now i have to choose if i can get a buyer then what do i get and here are what ive come up with
2 10" xplods and 2x 12" x plods running off x plod amps (this means i could sell only my sub and reuse the amp for the 10`s)
same as above but with 15" instead of 12
2x 10" pentagonal xplods and 2x15" pentagonal subs running off new amps (also might do 12")
2x10" kicker squares 2x12 or 15" kicker spuares with undecided amps
or possibly i might do just circular subs
as you can tell i do have a preference for sony as most of my kit is sony and im not too keen on mixing brands unless its for a good reason
also has anyone got any pics of some similar setups in hatchbacks (preferably mk4 or 5) but any hatch not vw specific
thanks in advance and as you can tell i do need your help to create somthing that can really push some Db`s and still look really good (ps the amps will most likely be hidden most of the time)
so...
