Fuel Relay
JWC
Fuel Relay
Post by JWC »
Hi, anyone know which is the fuel pump relay? I pulled out fuse 3 which is the injectors, when I did a compression test, but it did complain with a check engine light for a while afterwards. :roll:
Speedlaw
Moderator
Post by Speedlaw »
According to ETKA, it's relay spot number one, with relais 410. Does that make sense?
JWC
Post by JWC »
Does that make it no 1 in the fuse box? I haven't seen any relays. I will have a look sometime.
Speedlaw
Moderator
Post by Speedlaw »
Wait - I thought you were asking about the relay. Not the fuse.
JWC
Post by JWC »
I was asking where the relay is. I think they are in the fuse box. But I am not sure. Think we are agreed its number one now!
