leaning car
leaning car
my car is leaning to the right on the back. wot could this be???
Join the club, there are loads of Polos which do the same.
I've replaced the rear springs on mine, which did sweet f**k all and cost me a fair amount. Shocks, I haven't tried those but I keep being told that a knackered shock can't be to blame.
I don't understand!!!
If you find the solution, please tell me!
- Moderator
I'm 99.9% certain it will be a broken rear spring causing this
My blue CL when i got it had one broken (they go near the top & you cant always see them so clearly untill you have removed them).
Also the silver CL had 2 snapped rear springs aswell
As Haysey says.. it could be that the spring isnt seating in the rubber locator that sits right @ the top inside the rear arch
Bloody hell, I wish I had half an ounce of mechanical ability I'd take it off myself and check.
I've got an incling it's the rubber mount at the top, might not even have one!
I don't trust myself to dismantle important parts of a car like suspension without someone knowledgeable nearby, so I'm gonna have to take it to a garage again.
I'll get it looked at when it goes in to have the new brakes fitted - a job I'd do myself if I had the time.
Life's a pain.
Life's a pain.
- Sponsor
Rear suspension is a piece of cake to remove / refit (at least it is on the mk2 golf, and I presume that the polo is pretty much the same) - pretty much just unbolts top and bottom and pulls out Front suspension I can understand you not wanting to tackle though, that's a right bugger, lengthy and plenty of things to get wrong. I wouldn't be worried by the rear though if I were you
Alex - are they Spax springs that are on your car by any chance?
I noticed when we did the rears on Yoof's car at the weekend that his Spax springs didn't fit into the rubber cups very well at all. They were a very tight fit, and it took a lot of fiddling to get the spring seated properly in the rubber.
