What Handbrakes Fits In A Mk4 Polo?
Bedi
Post by Bedi »
after a leather handbrake for my MK4
Will the handbrakes from the following vehicle fit in my MK4 Polo?
MK3 Golf GTI/VR6
Logic says that it should fit since allot of the components of the two cars are similar... But I still need confirmation
also does anyone know how much the handbrake from the POLO GTI costs?
Speedlaw
Moderator
Post by Speedlaw »
The mk4 handbrake lever has different mounting points, so it would sit off centre if you lob it straight in. With some work it should be possible.
The mk3 handbrake lever is nearly identical as the Polo unit, but you need to loosen the cable a lot, it has a different lever point making it necesary (sp) to adjust the cable. Easy peasy though. The plastic cover that fits around the lever is a tight fit but it'll go.
I've not tried the Polo GTI lever yet, but it might fit. Not very helpful I know...
Col
Post by Col »
Mk3 Golf cover can be removed and used on metal polo mechanism 8)
BalinJu
Post by BalinJu »
cool clocks man, how much work did that take?
Col
Post by Col »
A lot!! :D
13twelve
Post by 13twelve »
the blue clocks thing is really mint
cinder
Post by cinder »
I have mounted a 2000 polo GTI hanbrake in my 95 mk4, mounting points are a perfect match, but as speedlaw said about lossening the cable, this has to be done on the GTI handbrake also, The biggest problem is that the mk4 plastic cover wount fit, and the GTI handbrake interiour thingy is moulded togeter with the ashtray and some other stuff, but a little modification and your banging.. I shall post some pictures when i start modifing mine.
Speedlaw
Moderator
Post by Speedlaw »
cinder wrote:I have mounted a 2000 polo GTI hanbrake in my 95 mk4, mounting points are a perfect match, but as speedlaw said about lossening the cable, this has to be done on the GTI handbrake also, The biggest problem is that the mk4 plastic cover wount fit, and the GTI handbrake interiour thingy is moulded togeter with the ashtray and some other stuff, but a little modification and your banging.. I shall post some pictures when i start modifing mine.
Interesting stuff, would really like to see it!
Col
Post by Col »
OEM but tastier!! :D
Could give you the part no's but then it'd be no fun and I'd have to kill you!!! :P :lol:
cinder
Post by cinder »
I shall upload some pictures when i get back to work (whensday) left the memory card with those pictures at work :(
