Hi all, i have 17" rimz on my 99 Treg polo n when i turn either side the rimz rub the inner arch not bad but at 106quid a tyre it does hurt!
i was wonderin if ne1 here had dis problem n wot dey did to resolve. I was finkin of lowerin it with stiffer springs dat way the body wont roll dat much n in theory it shudnt rub.
for 16" u have to use tyres size = 195/40/r16
but for 17"s u have to look for something smaller 195/??/r17 even theres no 35 or 30 with 195 and 205 will be bad too
so u have to look for tyres that fitt with them
Same problem have I with 195/50/15, car is lowered (front 60mm, rear 40mm) and it is horrible. I find out it's because ET is too smal (30 or something). When I put on my mate's rims (195/50/15) whit larger ET (35) it was waaaaay better and didn't rub at all...
thankx to all, the tyres i got at the moment are 195/40/17 Pirelli cost round £450. the ofset is ET35 and i mean their not that bad but sometimes the rubbing gets to me! dont want to get rid of these rims cox the only set in four stud!!!
i was finkin of lowerin it coz the rubbin problem is near the bottom of the arch, if i lower it the wheel will go in the arch more and it should stop the rubbin!
duno after spendin so much on jus tyres its hard to see em rub if u c wr im comin from! Myf to for 14" bbs cross-spoke's n lower it to the ground.
try arch rolling, the good solution to this!.. better than spending lots of money on ultra low profile tyres.
wont be that expensive for arch rolling, cheaper than wasting the tyres at a superfast rate!
Thanx. the car does get alot of attention esp when its sunny n iv jus polished it. Will find out bout the arch rollin!
Was finkin of either sellin the car as is or part ex with a facelift modle 1.4 standard n do that up but duno already put the clifford in dis n the facelift only comes with the standard VW alarm...... is that any good?!?!?!
p.s went out yday n som t**t stole the chrome ariel DAMM!!!!
8*18"? WOW! Dint knw alloys cud go dat big on a Polo wud av jus gone 4 a 9n if i did! Im unfortunatly sellin mine! Will eva sell car or rimz n get some borbet DesignA's in 16" n lower it! I do rather like the 6n2 standard and GTi but the insurence for GTi will be some £3000!!!
Wna put small alloys on a polo n lower it! Luk at link below, ma brvs beema it on 9*16" Azev's n bout two inch off the ground! Mine wud luk gud parked nxt 2 it!!!
