...but I have to add, the drive is wonderful!
phew you had me worried but if you do have the pressure surveilance make sure that the front left wheel only ever goes on the front left hub and that when you remove/ replace the wheels the valve MUST be at 12 o`clockciden wrote:@ Polo2K
...coooool down, it will be gone in 6 month! I said the drive is wonderful, NOT better than the Polo. But I've got to hand it to the French...the quality is good...and it's better than the Clio it replaces. And also, it's one Renault between 3 VW's
