1.4 16v 100bhp engine conversion
how much would it cost and where do i get the top mounts from
im not 100% on the original hp of the 16v but here are some allys to look down
exaust
air filter
cams
"power box" best 5 wires i ever branched into the ecu loom
ecu
under drive kit
you will probably not need all of these to get to 100 hp but if you go a little further whats the harm
if you would like to go to a little further still:
bore out the block to a higher displacement
port and posish the head
forced induction
etc
however you can make you car faster by ghanging the final gear ratio to make the box "shorter" i.e. less difference in between the gears
most of these are general ways of squeezing more power out of any engine
![Shocked :shock:](./images/smilies/icon_eek.gif)
exaust
air filter
cams
ecu
under drive kit
![Very Happy :D](./images/smilies/icon_biggrin.gif)
forced induction
![Twisted Evil :twisted:](./images/smilies/icon_twisted.gif)
etc
- Moderator
Not an easy conversion.
You will at least have to have custom made engine mounts, driveshafts and exhaust Manifold/downpipes.
Thats just the mechanical side, the elctrical part will be hard. For that you will have to use the 1.4 16v ECU and engine wiring loom and find a way of mating that to the standard Mk3 loom or use parts of the Mk4 loom aswell.
It will cost a lot of money to do and it would be far easier to drop in a G40 engine which requires no modification to fit. Plus you would have more power as standard than the 1.4 16v engine. Also G40's are easier and cheaper to modify than the 1.4 16v engines.
- Moderator
