Lowering?
Musicfreek2002
Lowering?
Post by Musicfreek2002 »
I know ive posted about this loadsa times but i can get hold of a set of 60mm springs for my polo, do i need to buy all new dampers or will the back ones be ok?
will i get any scrubbing cos ive got 195,50,15's?
spankone
Post by spankone »
you should be cool dude... and yes new dampers is alawys a good idea with new uprated springs
carmadaaron
Post by carmadaaron »
195/45/15s prevent rubbing when lowered
Black Dub
Post by Black Dub »
i would suggest when going any lower than a 40mm drop its best to get up rated dampers, will ride much better on them.
dubpolo
Sponsor
Post by dubpolo »
you can pick up a cheep set of spot on coilies for £250
http://www.tigerstyle.co.uk/poloforum/v ... 6453#96453
AKs_SlickPolo
Post by AKs_SlickPolo »
im up 4 lowering my mk4 too. trouble is there is mixed stories about dampers. Ive heard its not good using the standard shocks at all, and im just wanting to a minor 35mm drop allround. Eibach do springs that r compatible with OE Dampers, but some guy off another forum said then my OE dampers will only last less than 12 months. im confused? but getting a complete kit is usually costly!!! what to people on this forum think???? would it be okay to do a 35mm drop on standard dampers??? :(
Si_GTi
Moderator
Post by Si_GTi »
A -35mm drop on standard dampers should be OK, but you have to check the state of your OE dampers when you put the new springs on - if they're in good condition you'll have no problems :wink:
AFAIK the mk4 had oil-filled dampers, apart from the 16v which had gas-filled dampers. You could try looking for some 16v dampers if you want a better ride or go all out and swap the dampers out for uprated ones - although by the time you've forked out for new springs and shocks you could have bought those coilies dubpolo has pointed out and have adjustable ride height to boot 8)
Basically IMO, if your OE dampers are in good nick you'll be OK fitting lowering springs of up to -40mm.
jm2pw
AKs_SlickPolo
si_gti thats what i thought. But i just wanna make sure that my mk4 wont have another problem waiting in the next couple of months. i mean, i have not had any problems since i bought my Polo (its rock-solid 8) but i want to keep it that way, i kinda like to do things once and leave it if u know what i mean :lol:
my dampers seem to be good.
ride quality, i know springs will make a difference but i dont need super ride quality or anything. im happy wid it as it is. Just wanna lower it as if i stick some rims on it it doesnt look bus high.
How hard are they to fit, cos me and my mate were thinking of trying it out ourselves??? any1 done this themselves - i think bstardchild on this forum did??
dubpolo
Sponsor
Post by dubpolo »
i've done springs on my old MK4, i had -40mm drop with standard shocks no probs! Coilies are easyer to fit! belive it or not! the haynes manual give you a good idea of what to do! give it a go! just make sure everything is tight! (nuts and bolts i mean!)
Phil6N
Post by Phil6N »
Just wondering if anyone has any pics of lowering 60mm and 40mm on 15 195/45's by 6.5 wide? and i presume when its said "prevents rubbing" you still get the occasional rub? and can u still get full lock? cheers
carmadaaron
195/45/15 will NOT rub at all :)
Phil6N
Post by Phil6N »
Cheers dude
david burton
Post by david burton »
careful with the tyres tho - BF Goodrich are wider than most at 195. Mine rubbed at the back on a 60mm drop, and I had to move them to the front.
Phil6N
Post by Phil6N »
Got any pictures of yours on 60mm david burton? Cheers
dubpolo
Sponsor
Post by dubpolo »
are the arches on the MK5 bigger then? cos am lowered 80mm on 195/45/15 i i have no rub at all! even with a fully loaded car!
