what tyre pressure are you running??
steveo3002
Post by steveo3002 »
just wondered what tyre pressure you guys run? std 145/80/13
Tahrey1043
Post by Tahrey1043 »
i'd have to check inside the fuel cap, but i think it's 25psi standard, and up to 32psi (rear - 28psi front) when heavily loaded.
steveo3002
yeah i run around 25, but i feel its a touch low..then again i had it higher once and it was a touch dodgy in the rain :cry:
stuart_hatch
Post by stuart_hatch »
I have them allways at 32, is that a bit high then :S
Gareth_GT_Hatch
Post by Gareth_GT_Hatch »
stuart_hatch wrote:I have them allways at 32, is that a bit high then :S
yep, I think I run 26psi in both cars.
Tahrey1043
depends on the car, the tyres, and the conditions (loading, air temp, whether you're going for grip/speed or economy/comfort etc)
but manual reccomends, for mk3 at least (mk2 can probably be a little lower because of less weight?) ... *checks book* er, lol... exactly what I already said. How spawny is that.
that's for the singlepointers on 145/80 or 75, 155/70, and 165/65s. GT and G40 it's higher, with diesel somewhere in between.
so you might be able to slacken them off for the mk2, but if you want to do any hard driving even on the lighter car/weaker engines keep it somewhere in the mid to high 20s. Higher speed = higher pressure (?)
optima21
Sponsor
Post by optima21 »
I used to run 29psi on the front and 25psi at the back when I was running 145/80/13's as that reduces by tyrewear and made the car understeer less in wet conditions.
gofasterpinch
Post by gofasterpinch »
28 front and 40 rear
like that to baloon the rear tyre pattern and reduce understeer and makes the handbrake better
GroovyCarrot
Sponsor
Post by GroovyCarrot »
gofasterpinch wrote:28 front and 40 rear
Erk.. don't your rear wheels lock up as soon as you put some pressure on the brakes like that? I have enough trouble controlling the back end under heavy braking on 25/28..
gofasterpinch
suprisingly, no, i wish they did!!!
does make it a bit more twitchier tho 8)
Phoenix
Post by Phoenix »
depends what i'm using the car for
Racing : 21-23/35
Round town : 28/35
Motorway : 32/35
