17's or 16's
EdN
17's or 16's
Post by EdN »
I noticed a some 17's on a Mk5 polo the other day with 205/40/17 tyres. Surely the speedo gets screwed up?
The gti has 195/45/15 then you can put 16's on with 195/40/16, surely 17's are a no-no with 205/40/17.
harry
Post by harry »
17's are the way to go :D , i got 195/40/17 on mine and it is slammed as well and it looks the business.
KarlM
Post by KarlM »
go for 17s! the gearing is a bit longer, but high speed handling improves.
The problem with 16s is that unless your really careful choosing the style, they look too big for euro style and to small for brit style.
harry
Post by harry »
big is beautiful :D
MYpoloGti
Post by MYpoloGti »
ive got 17's on my Black mk5 Gti looks the bis , 206/40/17
mmmmmmmmmmm
ill have a pic up by saturday :D
harry
Post by harry »
my polo gti does it not rub anywhere?? :D
Speedlaw
Moderator
Post by Speedlaw »
The speedo does get a bit screwed up, actually- The Germans are required to re-set their speedo to reduce the margin of error. It's one of the TüV requirements after fitting 17's.
harry
Post by harry »
does anyone know how much out the speedo is if your running 195/40/17 tyres??
wul3er
Post by wul3er »
Im only puting 15's on mies as ive only got the 1.4 version and i dont want to slow it down anymore. Im dropping it 40mm.
Im finding it hard to get some parts for the Polo mk5. Does any1 know any websites/places that stock mk5 parts.
KarlM
Post by KarlM »
not looking hard enough mate! :lol:
www.venommotorsport.com
www.ra-design.co.uk
www.awesome-gti.co.uk
hope that helps
polo2k
Post by polo2k »
or absolutly any thing you need and someone on the site will be able to source it as this site is getting more and more geographically diverse so we end up with more options
norton
related fodder
Post by norton »
Will 17" 205/40/17 with a 40mm spring reduction really be ok on my 1.4
se mpi , got to mail order the wheels and cant send them back.
I dont want to carry out any mods if i can help it.
Cheers ........ Norton.
polo2k
Post by polo2k »
i run 195 45 15 bridgestones and am always at -60 or below with no rubbing even at -12cm it doesnt scrub at all as long as the coils are set hard. the problem at -12 is that the driver side drive shaft hitts the chassis leg
pettsy
Moderator
Post by pettsy »
i've got a link on my pc at home that gives you all the correct tyre sized to use to keep ure speedo accurate when you upsize on alloys. someone remind me when im next on msn and i'll post the link!
david burton
Post by david burton »
