does anyone know how to suspend the sub surrounds in the air while you fibre glass it, i heard a roomer about using chicken wire, but need alittle more help then "just use chicken wire" so if anyone can explain how to do a boot build or know of any DIY on the internet then it would be most helpful
cheers
rob
9n boot build
Randall
from previous projects ive seen n read they are usually held in place with sum wood strips similar to a tripod form, then coverthe item with clothe n fibre glass awayRobw53 wrote:i no i have them options but i want to know how to hold them into the place/area where you want them while you cover it with fibreglass matting.
rob
