My 1991 G40
Post pictures of your car! (Max size 30k each - 800x600)
Krupa
My 1991 G40
Post by Krupa »
Spec:
OWNED SINCE March 2000
ENGINE
1272cc, multipoint injected, supercharged; Pitstop Developments Full Blend Supercharger; SNS Stage 5 chip; G60 Injectors; 68mm alloy pulley; GT inlet manifold; Boost return pipes removed; oil catch tank; Longlife stainless steel exhaust with decat pipe;
CHASSIS
Spax Adjustable rate dampers; -40mm Spax Springs; Polyurethane Track Control Arm bushes and anti-roll bar mounts (front); Bonrath polyurethane shocker bushes (rear); Steel Front Brace Bar; Polyurethane bump stops;
BRAKES
Standard G40 calipers and carriers (painted silver); Raicam pads; Brembo discs; DOT 5.1 Brake Fluid; Pitstop Developments Steel Braided Brake Hoses;
WHEELS AND TYRES
15x6.5 Adikt Speed wheels; 195/45 Good Year Eagle F1 GSD3 Tyres;
EXTERIOR
Clear indicators; Late spec rear light clusters; OE Fog Lights with Xenon bulbs; de-locked door handles; Wing Aerial Hole smoothed;
INTERIOR
Corrado VR6 Leather Steering Wheel; Aluminium Gear Knob; Leather Gear Gaiter; Scirocco GT2 "Modekaro" trim;
SECURITY
Toad Ai606 CAT1 Alarm and Immobiliser;
