Interesting Fault with my electric front windows
Well it happened once before and i though it was just me coz i was tired and when i'd taken the key out of the ignition and put it back in they worked fine!! The problem?? Well.....
When you press the right buttonof the electric windows the drivers should go down...right!?! well last night NOPE decided to do the passenger one and obviously the passenger button (on the drivers door) did mine the drivers window, played with the windows for a bit didn't change so when i got home i switched the engine off took the key out then put it back in and turned the key and HEY the buttons were back to normal!! Just wondered whether anyone else has had this interesting problem.
Today it also seemed a lil unhappy like it does from time to time and it's performance was a bit poor .........i'm starting to wonder if i'm dealing with a descendent from Herby??
Yep, I've had this on my car once before, just after I washed it. It's never happened again so I attributed it to me getting something wet.
Stupid VW electrics
I also changed the Gamma for a Blaupunkt Woodstock DAB52, if I remove the face-off panel whilst it is still playing the next time I start the car (without putting the panel back on) the radio comes on - now that is freaky.
Stupid Blaupunkt electrics
Stupid VW electrics
- Moderator
I never bothered to mention this before because I didn't want to make a topic just or it. But I've had another problem, apparently its pretty commmon on VW's.
Nearly every time I'm doing my window up and I hit a mini-roundabout or speed bump the window will get confused and go back down Once it went half way up, 3/4 down and fully up again.
Wierd
Wierd
I get a variation of this. If I hit a speed bump with a window in the process of going either up or down, it stops. Then, from that point on and until the ignition is turned off and on again, the "one-touch" feature is disabled.I never bothered to mention this before because I didn't want to make a topic just or it. But I've had another problem, apparently its pretty commmon on VW's.
Now, I just avoid using the windows when going over speed bumps.
(Something else that fits into the "turn the stereo up so you can't hear the rattles category")
Deek.
