Boot popper?
mmh
Boot popper?
Post by mmh »
Anyone here fitted one of these boot release kits?
http://cgi.ebay.co.uk/Falcon-Electric-B ... dZViewItem
Are they easy to fit?
Advice welcome, thanks,
Mo
cinder
Post by cinder »
Hi there, I have fitted a kit like that on my boot. No problem to fit, I removed the whole look when i fitted mine but i test fitted it before removing the look and there is lots of space for the solenoid. If you remove the rear wiper while you are at it you can get a small glass cover for where the wiper comes through the window. Then you can connect the solenoid release to the wiper trigger arm on the steering wheel. This seems to be the most common thing to do.
Good luck. :)
mmh
Post by mmh »
Cheers Cinder,
I'll give it a go.
Thanks, Mo :)
