hi guys does anynone know the standard bore, stroke and compression ratio on polo gti pistons.
thanks
gti piston size?
No. of valves: 4 per cylinder
Cubic capacity, ltrs/cc: 1.6, 1598cc
Bore/stroke, mm: 76.5/86.9
Max output, bhp/kw @ 6500 rpm: 125/92
Max torque, lbs.ft/Nm @ 3300 rpm: 112/152
Compression ratio: 11.5:1
^^ From the original Polo brochure circa 1999, which can be found here thanks to dmwright![Very Happy :D](./images/smilies/icon_biggrin.gif)
Any help?
Any help?
