What do you think about my idea of 1.4 16V/1.6 AEE hybrid, or home made 1.6 16V
Original engine is a 100hp 1.4 16V AFH.
So is it possible to stroke a 1.4 16V AFH engine by using a 1.6 AEE crankshaft and conrods to gain extra 200cc.
Piston diameter is the same in both engines, I assume the engine blocks are identical too.
Are crankshaft and main bearings the same (or compatible) in both engines? Are 1.4 16V pistons compatible with 1.6 AEE conrods?
