Hi guys.
I have a 1996 1.4 and had 'stalling at junctions' issues. It turned out that the brake servo vac pipe was split at both ends. Bodging it with insulating tape only partly stopped the leak, but the car ran fine.
£17 and a new pipe later, the car idles too slow and hunts badly, and it stalls again
I've done a searchy and read about common problems with the idle control valve, but am puzzled why it ran OK with a slight vac leak.
My other guess is that the previous owner turned the idle speed down to compensate for something.
First question is. Where is the idle speed screw ? (I might be blind but couldn't find it)
Second is. Any other ideas ?
Thanks for any help.
