Lower centre grille
Lower centre grille
How do you remove the lower centre grille.
Yep clipped all the way around, really hard to get them out, but use force and be careful
I used some rope type thread fed through the holes to get a better leverage on it. I ended up breaking all the clips along the bottom, but did not mind, as I was replacing the grille with the honeycomb version.
