I have always hated my sidelights as they give off a yellow glow. So i decided to buy some zenon bulbs that give off a bright white with a blue tint. I read on here that its impossible to change the sidelights without removing the bumper. Well i managed to do it without removing the bumper and using a flathead screwdriver.
The main problem is that there isnt enough room to get a good purchase on the bulb socket. Some ppl advise you to tug on the wires but i would be more careful incase you break the wire.
I am i simply used a precision flathead screwdriver to get the socket out past it's retainer using a a lever action ( like opening a tin of paint ) This worked a treat. Fitted lights and tested before fitting them back!!!
Walaa!!! Done
It can be done!
Will post in DIY and i know i shoulda only posted it there but thought you's might wanna know. Can post pics if you's want
I'm sure it'll be helpful to Non-GTi owners if it works on them ok, if it doesn't work on the GTi's then well I guess it just doesn't work, but as I say I'm sure some people will find it most helpful.
The back on the none-GTI headlights just pops off, once thats off you just twist the sidelight and it pops out. Then all you gotta do is the same in reverse. Jobs a good un...
With the gti you have to remove the bumper due to the xenon light. Something ill be doing very soon, if i can be arsed!
No, you are screwed with a GTi as the back is literally screwed on, so unless you have a screwdriver that is 1cm long, it cannot be done. But dropping the bumper is a 5 minute job. You don't even have to take the very bottom panel off, it will swing forward. Still its a bit of a pain having to take the bumper off at all!
the battery gets in the way of the left side light on the GTI
I know this from personal experience whilst trying to change a main headlight bulb with my mate
