answers on a post below please
9n coilovers
9n coilovers
Ive been searching for a set of coilovers for the 9n that go lower than 60mm but with no luck!! i was told FKs go to 110mm, but it seems they only do 55mm!! come, someone must sell them with a decent drop, question is.....WHO?
Check www.kw-gmbh.de
They have coilovers that will go down to 65mm. Take those mm's with a pinch of salt though, in many cases they list the drop that is acceptable to the German TüV, but IRL they can go down further. Don't know if this is the case with KW too, but it is common practice.
I don't know any slammed 9N's personally, but judging from these pics:
KW Var. 2 on 18's
KW Var. 2 on 17's
KW Var. 2 on 16's
KW Var. 2 on 17's (claimed -85mm)
KW Var. 1 on 17's
KW Var. 1 on 17's (our very own Mole)
I am slightly biased since my Var. 2's are in the mail, but the only other coilovers I could find were custom made H&R's.
KW Var. 2 on 18's
KW Var. 2 on 17's
KW Var. 2 on 16's
KW Var. 1 on 17's
KarlM
Air bags give a similar ride to your standard suspension but can be adjusted by regulating the amount of air in them. ie if the cars is jacked up then the bag is full of the air and the suspension is quite firm.
Rayvern are developing hydraulic kits which have coilover type systems in the boot for adjusting ride.
See my post in Chassis (airbags) which has some contacts details.
Careful with there website though.......
i spent an hour or so on it and am now completly addicted to the lo rider scene! looking for a derby to fit 'dancing' hyraulics to - with wire wheels and candy paint!
polo2k
i just want to add that if your wanting toi get kw stuff and want to put it on its belly get the V2`s as you WILL need to go most of the way hard to stop bottoming out
oh and also the suspension isnt nessesarly the limit to how low you can go, on my mk5 i ended up at -12cm at the front (for inters cos a certain member on 16"`s looked lower
) and rater than damaging the suspension i enged up with my RHS driveshaft hitting the subframe, chassis leg, back of the sump etc so watch out for that
oh and also before you go totally belly down get a front lower strut brace. i have an omp skid plake (for a mk4 but it can fit) however when im in totally slammed mode it actually suports the car a little because it hangs down a bit, and that strut brace has saved me a ot of times (hence the curve on it
