Hello
Does anyone know if the rev limiter of polo gti can be removed with ecu remaping? I refer to 2000 model with siemens ecu....
Has anyone done this?
Polo Gti_rev-limiter
superchips can usually raise the limiter but not with a siemens ECU, i know this cos i work at the workshop for scotland superchips (although i dont fit them), and my gti has a siemens ECU!
i had my car on the rollers again at the weekend and maximum power output was at 6250 rpm so there is no point in movin the limiter!
Slight diversion from the thread but where do you work Grum? And do you do suspension? Thinking of getting the GTi dropped 30mm and am over in Fife quite a bit. If you do it, how much?
I'd also be interested to know what superchips can do for the car, like what sort of power increase you get?
Cheers!
Cheers!
