Front indicators
D-Dub
Front indicators
Post by D-Dub »
How the hell do you get them out :shock: Ive bought some silver-tech bulbs to replace the nasty orange ones but i cant for the life of me get the indicators out, i dont wanna break one as they seem delicate. Can anyone help me? Cheers :D
stu nwpoc
Post by stu nwpoc »
I will try and describe this to the best of my knowledge
Lift the bonnet and above the indicators there is a small peice of plastic which looks something like a radiator bleed key (but ALOT smaller) with a philips type screwdriver bit cut out in the middle (if you know what i mean)
You should be able to turn this 45 degrees, the plastic lugs should be facing North/South and then you can CAREFULLY pull it upwards towards you, this will then release the indicator and it should then quite easily pull out from the front !
BUT BE CAREFULL ! THEY DO SNAP !
:D
