What is it??
What is it??
What is it??
brianpologti
Re: What is it??
Its a little red [x] iconHK 6N2 wrote:What is it??![]()
http://forum.caranddriver.com.hk/read.p ... 3&t=527422
Its the air conditioning. If you look there is one rad on top of the larger rad, so it has an AC rad, that is the feed to it.
If it isn't that then its the PAS cooler which also runs down there too. Usually PAS is cooled only with a pipe running in the air stream.
Either way, its most definately a cooler!
