Side lights
clees
Side lights
Post by clees »
My passenger side, sidelight bulb has gone. How easy is it to replace!!
cheers :roll:
vr6south
Post by vr6south »
Dead easy. Lift up the bonnet and you'll see a plastic phillips type head just above the sidelight. Turn it and it will spring up, lift it up gently. The side light should then slide forward. Don't try to force anything as it's all pretty fragile. I know :!: Sorry I'm thinking indicators :oops:
PhilGTi
Post by PhilGTi »
Side light, meaning the headlights?
GMANGTI
Post by GMANGTI »
i think the actual meaning of a sidelight is the same lights you put on for parking, or the first lights to come on before any others.....
if this is the case then if it is on the passenger side you will need to remove the battery (to make it easyier) then remove 3 screws from the bk of the housing of the main lights and then either twist and pull the sidelight housing or jst pull cant remember how i did it??
george
