Beta Radio - strange one!
Discuss In Car Entertainment
howett
Post by howett »
I have a Beta Radio in my Mk IV Polo and got in yesterday to go to the shops. For some reason I have always had to input the code everytime i use the radio as does not seem to store it. Possibly something to do with the wiring. Anyhoo all is usually fine. However when I tried the code yesterday it said is was wrong so I thought I might have made a mistake entered it again and same thing happened so I now have the '2 SAFE' displayed on the screen. According to the instructions it will be there for an hour and then will be back to normal. HOWEVER when I went to the car today - it was still there?! Have tried disconnecting the battery for a few seconds, enough to reset the clock, but no joy. What is going on?! Thanks in advance.
CalvinGTI
Sponsor
Post by CalvinGTI »
Gently remove the offending stereo remembering to de-cable the back of it, place it on the floor, preferably on a solid concrete floor.
Raise your right foot to about waist height and kick your foot down on top of the stereo with as much power as possible.
The Stereo should smash into a few million pieces, thus reducing future frustration as well as a quick high from the release of endorphins into the body :)
Should solve your problems mate !
Da-Stereo-Doctor
PS - i know this wont get the stereo working again, BUT you'll have a damn good reason to now go down the shops and invest in a real one !!
:-p
Giorgio
Post by Giorgio »
or you could take it back to the shop and get a different one :roll:
howett
Post by howett »
At the moment this one does everything I need it to.
inder
Post by inder »
You need to leave it swiched on for an hour, then it should allow code re-entry (do it correct this time hehe :P )
howett
Post by howett »
inder wrote:You need to leave it swiched on for an hour, then it should allow code re-entry (do it correct this time hehe :P )
Thanks. So does that mean I have to have the car running/ignition on for an hour?! If not then I'm quite sure the radio switches itself off after an hour when key is removed?
inder
Post by inder »
No need to have car running, just turn on the radio and come back after at least an hour.
Not sure about that sleep function, but as the radio is in SAFE mode, I think it won't switch off like this.
Giorgio
Post by Giorgio »
wont this kill the battery?
ModifiedMadness
Sponsor
Post by ModifiedMadness »
No, the car will be running, therefore charging the battery as if you are driving it :D
