Elect Sunroof Help
Bran
Drives: VW Polo 1.2 TDI 2012
Elect Sunroof Help
Post by Bran »
My electric sunroof has totally stopped working, i have checked the fuse and that is fine. I'm turnin the nob and nothing is happening ????
Any help would be great
thanks in advance
Chris
inder
Post by inder »
Sure you are checking correct fuse?
It could be the actual switch that is dead or if you have not used it in a while, it might have seized up? Perhaps manually open it and WD40 the runners if this is the case?
Hope helps
Bran
Post by Bran »
i actually opened up behind the switch at the weekend, and it comes with like a metal handle to turn the motor which opens the sunroof..
you cant actually see any mechanical works, it just looks like a big expensive motor in a box.
I found out from the previous owner (my boss) that he hardly ever used it, then one day he thought he might use it (about 6 month after he last used it) and he just heard a bang and the thing never worked - i really hope the motor aint buggered, cos that thing looks wayy expensive
inder
Post by inder »
From the description he gave, sounds like the motor is dead! Keep looking on ebay, they often come up cheaper than retail part
