ECU Replacement
professor_chaos
ECU Replacement
Post by professor_chaos »
Hello!
I've got 1996 1.4 16V. I have replaced the ECU with a new one and my car starts and dies after 2-3 seconds.
Is ECU connected somehow with immobiliser?
Shuould I go to dealer to have it coded someway or sth?
Tigz
Post by Tigz »
Is it a genuine Polo ECU for your engine code?
Yes, your ECU contains your imobilisor code, although I would expect it not allowing it to start, not run then cut out.
Have you got access to VAG .com?
Why did you replace the ECU?
benny_polo
Post by benny_polo »
the immobilizer on polos will allow the egine to start and run but only for a few seconds, what you need to do is have you key re-matched with your new ecu
if you have vag-com it is possible with this but you need the 4 or 7 digit skc (serect key code) obtain from the main stealer, failing that take it to the main stealer :shock: or look in yellow pages normally few places in every town that does key recoding that tends to be cheaer then the mai stealer
professor_chaos
ECU Replacement
Tigz wrote:Is it a genuine Polo ECU for your engine code?
VAG 409-1 is enough? I might get access to that one.
Well, I have N-group ECU installed at the moment it consumes about 16l when driving normal. But normal driving in N-group car means you shouldn't go lower than 3000 rpm or it might stall. It idles very rough at its 1500.
I need to drive it sometimes to training place and I would save a lot if I could use standard setup. Except ecu engine is serial in accordance with appendix J for N-group.
I got a brand new ecu from ebay for AFH from trusted seller. I checked all codes in ETKA so it is certainly ok. I wanted to have 2 ecus and swap them when necessary but I didn't know about that immobiliser connection.
I wonder if it is possible?
Is ecu programmed for the immobiliser or is immobiliser programmed for new ecu. Maybe I should have 2 immobiliser units one for each ecu but both programmed for the same key?
Any hilight on these issues? I appreciate any comment.
