Can anyone enlighten me?
I f you listen to mine, the changeover is even more obvious! Above 4k the sound of my new exhaust changes completelyandyg wrote:Having read that article you should have all the info you need.
In the Polo the VVT starts kicking in at around 3500 rpm, and the valves are fully open at around 5750 rpm. If you listen carefully when you take the car up the rev range, the noise of the engine gets louder and changes pitch over 4k to 5.5k, it sorta steps up a level and you get a slight burst in power. I love that sound
