wiring in 6" x 9" speakers into the back of my cd
Nicks
Post by Nicks »
need help wiring it in to the cd player as i am not sure where the cables go into..if ne1 cud help it wud b appreciated
Randall
Post by Randall »
Have u got an ISO Adapter between the standard wiring and HU?
If not get one, then you will need to chop the two green wires n the two purple wires as these will represent rear speakers. Then you will need to run the wiring down the car and join them up with sum bullet connectors
Hey Presto
Rich
polo boi
Post by polo boi »
so u dnt connect the speakers up 2 the front tweeker speakers?
or can u do that aswell
mbenz1
Post by mbenz1 »
poloboi - the front 4 speakers(2tweets, 2woofers) run off the front outputs as they are components.
you just need to connect the wires up to the rear outputs on the headunit iso adapter to the speakers and your away
