right guys im ghonna fit my coilover tomorrow. anything you can swing my way as far as advice goes?
anything that you think may help u guy out?
thanks in advance
kenny
fitting coilovers
When u get back to fittin the 2 bolts on the bottom of the front struts, tighten them up just enough so u can still turn the bolts, turn the top bolt til the top of the brake disc sticks out as far as it can, then use a flat screw driver, put it in the vents in the disc at the top, pull it out towards urself as much as u can (its easier with a friend to help u) then try tighten the 2 bolts!
this little hint is to help set the camber to what it should be!
