MK V Polo front door speakers
Discuss In Car Entertainment
zahir_213
Post by zahir_213 »
Need to replace my front door speakers, would like to run them off the headunit which is giving out 50wattsx4. Can anyone recommend component speakrs to fit into the factory holes?
Josh_PoloGTi
Drives: BMW E85 Z4 3.0i
Post by Josh_PoloGTi »
Focal
Focal
Focal
8)
KarlM
Post by KarlM »
so what speakers do you have Josh? :P
It depends what system you want - for sound quality you cannot beat Focals (hence Josh's obsession!)
But for SPL systems (more bass) i've found my AudioBahn AW525s kick like a mule (rated at 100w rms - so they wont even be breaking into a sweat running off the head)
hope that helps
simon pope
Post by simon pope »
Karl how much would it be for a set of those audiobahn a525ws speakers?? can u get hold of any for me??
spope
KarlM
Post by KarlM »
I got mine from Music World in Sheffield for £100 notes
simon pope
have u got a phone no: or an email address for them??? cheers
zahir_213
Post by zahir_213 »
anyone think these will be ok?
JBL GTO6506Ce
on this site
http://www.mcs-direct.co.uk/acatalog/MC ... rs_80.html
thanks
KarlM
Post by KarlM »
they should be fine (the GTO series is quite bassy IIRC)
zahir_213
Post by zahir_213 »
im about to order the jbl speakers, but i need to be as sure as a i can, that they will fit without messin about. Does anyone know the maximum depth for the 16.5 cm speaker? and also for the tweeter?
gilmore
Post by gilmore »
is the standard headunit in the polo gti decent enough to use when upgrading the speakers - I too want better set of components in font plus comps in the rear too.
think head unit is 4x25watts?
dont really wanna mess around with changing head unit - have an alpine one sitting in my flat but then will need to change Cd player etc...
cheers
Josh_PoloGTi
Hi mate
I have started using my Gamma again, but I've connected 2 amps to it (1 powers the front speakers, one powers the sub). I have disconnected the useless rear speakers.
My front speakers are Focal Polyflex 165H Components.
The Gamma is a fine headunit as long as it's used to drive an amp. It is a bit gutless on it's own unfortunately
Speedlaw
Moderator
Post by Speedlaw »
Josh, does that Gamma have proper connectors (RCA) to connect the leads to feed the amp?
Josh_PoloGTi
Kind of....
There is a small yellow connecter that goes into the back of the head unit that provides RCA's, so no dodgy line level converters needed.
RCA's are not actually on the back of the unit, but the adapter cable goes into a specific socket for line out.
Autoleads makes the correct cable.
J-O
Post by J-O »
I also have the Gamma head unit connected to 2 amps (4 speakers and 1 sub)...it's going fine...
the only thing i regret is that there's only 2 RCA and not 3...so I cannot set up the sub volume indepently...but otherwise, it's working fine. Juste buy the ISO yellow connector with the 4 cables (front R-L, back R-L) and the remote and that's all...
Recently, I was looking to the possibility to fit a PS2 or X-Box into the car...but the Gamma head unit doesn't have a IN RCA...but I found this:
this thing can be plugged into the CD changer ISO plug and you should be able to connect it to any device (PC, Mp3 player, ...)...they are even saying that you can use the head unit as a remote control for Winamp :shock:
