my cars misfiring
Posted: Wed Feb 22, 2006 11:11 am
by spot_on_jon
just took it out for a spin, must say its quite low on petrol but shes misfiring all over the place, try puttin me boot down and it doesnt wanna move, it sounds like a popping diesel
any idea what could be wrong?
i had thought it could be dirty petrol or sumthin?
Posted: Wed Feb 22, 2006 1:25 pm
by 13twelve
Probably ignition leads.
Search the board, theres a few causes and fixes to misfiring
Posted: Wed Feb 22, 2006 1:46 pm
by polo boi
change ur spark plugs, an look at ur plug leads, they cud b split, it cud b dirt aswell so mabye u shud change ur fuel filter, basically give ur car a service, how may miles are onda clock, coz if it was really serious, it cud b pistons but just check out the plugs 1st,
Posted: Wed Feb 22, 2006 3:09 pm
by Ant_6n
seems to be an answer to everything but try cleaning the throttle body, using carb cleaner or somethin, or try filling her up with optimax.
Posted: Thu Feb 23, 2006 12:30 am
by spot_on_jon
polo boi wrote:change ur spark plugs, an look at ur plug leads, they cud b split, it cud b dirt aswell so mabye u shud change ur fuel filter, basically give ur car a service, how may miles are onda clock, coz if it was really serious, it cud b pistons but just check out the plugs 1st,
yeh she needs a gud service!!, just ive its never done this before, all of a sudden came on
tryed puttin me boot down and it just started doin it :?
mind it hasnt been move for about 3 or 4 months tho??
Posted: Fri Feb 24, 2006 10:54 am
by astirl2809
Had a similar problem a little while ago. Managed to cure it by changing the plugs and leads.
also try adding some injector cleaner. If youve left the car for a while then taken it out for a spin with low fuel you may have dragged some crap from the fuel tank into the injectors and maybe blocked them.
Clean the throttle body as well.
Hope this helps..
Posted: Fri Feb 24, 2006 12:21 pm
by polo boi
yea mine was also sittin 4along time an wen i was 1st drivin it, it was dead, it just needs run in again, if u havnt got injectors, dnt use redex injecter cleaner as ur car might run even worse as alot of crap is takin away an the engine will b even more worn, just change the plugs an oil/filter, that shud slove ur problem :wink:
Posted: Fri Feb 24, 2006 2:11 pm
by dragon_green
Any MK4 should be injection :?
The most basic engines are single point while others are multi-point. I've used redex injector cleaner (red fluid) on my 1.3 SPi without problems.
Posted: Fri Feb 24, 2006 2:19 pm
by polo boi
well ive only a 1.0 an i know 4 a fact that if i add that stuffin2 my car, it will sound like a tractor afta, 100k onda clock, well worn in, so by addin redex, its gonna really clean it an the engine will b rattely coz its worn so much
