just took it out for a spin, must say its quite low on petrol but shes misfiring all over the place, try puttin me boot down and it doesnt wanna move, it sounds like a popping diesel
any idea what could be wrong?
i had thought it could be dirty petrol or sumthin?
my cars misfiring
spot_on_jon
spot_on_jon
yeh she needs a gud service!!, just ive its never done this before, all of a sudden came onpolo boi wrote:change ur spark plugs, an look at ur plug leads, they cud b split, it cud b dirt aswell so mabye u shud change ur fuel filter, basically give ur car a service, how may miles are onda clock, coz if it was really serious, it cud b pistons but just check out the plugs 1st,
tryed puttin me boot down and it just started doin it
mind it hasnt been move for about 3 or 4 months tho??
astirl2809
Had a similar problem a little while ago. Managed to cure it by changing the plugs and leads.
also try adding some injector cleaner. If youve left the car for a while then taken it out for a spin with low fuel you may have dragged some crap from the fuel tank into the injectors and maybe blocked them.
Clean the throttle body as well.
Hope this helps..
Hope this helps..
polo boi
yea mine was also sittin 4along time an wen i was 1st drivin it, it was dead, it just needs run in again, if u havnt got injectors, dnt use redex injecter cleaner as ur car might run even worse as alot of crap is takin away an the engine will b even more worn, just change the plugs an oil/filter, that shud slove ur problem
dragon_green
