Remove Handbrake Cover
Pedro_Hilario
Post by Pedro_Hilario »
Dont know if this is the right section, so feel free to move it to the right one.
I cant figure out how to remove the handbrake plastic cover.
I've learned how to remove everything else on the hanbrake except what i need the most, which is this cover.
Here's a pic of what i need to remove ( in the red rectangle)
Pedro
R1CH
Post by R1CH »
ive been trying to do this for ages,,,,no idea how mate,,,i just gave up.
mysteryboy
Post by mysteryboy »
You have to saw it off dont you?
Saw it down the length & then peal off...
R1CH
Post by R1CH »
f*****g hell,,,i hope not,,,i hate having to saw things off.
david burton
Post by david burton »
it's a complete pain in the @ss job, very tricky to do,
Giorgio
Post by Giorgio »
You dont have to saw it off, because this would mean it was moulded around the handbrake.
This is a guess but I think you might have to take the button off and it all slides out (towards the windscreen)
R1CH
Post by R1CH »
correct me if im wrong but this sounds like a job for good old..........DREMEL MAN.
Giorgio
Post by Giorgio »
Dremel Man is not needed. VW did not mould it around the actual shaft.
(shaft is a funny word :lol: :lol: )
Mr Haynes is needed 8)
david burton
I don't think haynes helps at all.
and it could easily be a "one way only" fit. depends on the clips.
ukmic
Post by ukmic »
yes you have to saw it off, and if your wanting to fit a richbrook handbrake or anything like that you have to file down ALOT of the top and underneath of the handbrake
remover
Post by remover »
you do not have to saw it. check the underside of that part and you will find a small slot (a square), just press in there with a screwdriver and pull the handle out. You can feel that with your fingers if you go along.
Pedro_Hilario
I cant saw it off. I'm thinking of getting a cupra leather cover on there. If that doesnt fit i'll be stuck without a handle on there.
I'll try tomorrow has remover said : screwdiver in that little square.
I'll let you know has that goes.
Pedro
