Passenger side window not working
About a month ago the passenger side window stoped working for no reason. If you press the button it makes a clicking noise but nothing happens. I haven't got round to taking the door panel off yest to see whats wrong. What could be the problem and what am i looking for/how do i fix it? Cheers
PieGTi
Just fixed my passanger motor this morning.
Had exactly the same symtoms. Was simply a sticky motor.
The way to fix is take door card off then, peel back sound proofing untill the middle where the motor is,
then tap the motor while pressing the switch.
once window is moving simply refit.
Hope this helps
Hope this helps
