as above, right b***h. I used a piece of old electrical cord or string and threaded it thru
there are clips all around the edge of it
just had another though, perhaps you could use a coping saw to cut the thing into small sections, going thru the diamond holes to the edge, say in half or four pieces, should break out easier then - that is if you don't want to save it
