vwII brake upgrade..parts check ??
steveo3002
Post by steveo3002 »
im getting a pair of vwII calipers from mr groovy carrot of here
im hoping to upgrade the brakes on my 1988 f plate 1300cl squareback..can anyone confirm what else i need and whats what
would i be correct thinking i need...
239 vented mk2 golf gti discs
pads from a 239 gti
then do my orig hoses fit ?
how much of a improvment do they make?? im kinda used to mk2 brakes now :oops:
SpikeyG40
Moderator
Post by SpikeyG40 »
i think its the VWII calipers that are fitted to the G40.
so would i be right in saying that a G40 set up is what you require? do you have the carriers too?
Regards
Doug
steveo3002
just got the calipers at the moment....
SpikeyG40
Moderator
Post by SpikeyG40 »
ahh....well.....
you'll need the carriers for sure as the standard polo ones differ from the g40 ones. then you'll just need disks and pads as far as i'm aware!
here is a pic which shows the carrier on the G40:
Hope its of some use to you!
regards
Doug
Gallagher
Post by Gallagher »
The VWII calipper is the same whether it is on a golf 1, golf2 og g40.. U can also use the carriers from a regular golf mk1 with VWII calippers.. it needs small mods. but no problem..
GroovyCarrot
Sponsor
Post by GroovyCarrot »
I know the design is different on the G40 carriers, but I thought it was possible to use VW1 carriers with VWII callipers? I could have sworn someone told me that was possible.. or am I thinking of the pads?
