Momo wheel in airbag model (Removing Airbag Light????)
SAM_MK4_19D
Post by SAM_MK4_19D »
Hi All,
I've fitted my Momo race steering wheel and my snap off. The problem is I now need to remove my airbag light. Stripped the dials out last night and looks like I need to take the pointers off and remove the dials to get at it. Am I right? Mine is a post 98 with the warning lights in a rectangle between the rev counter and the speedo with the fuel and temperature guages above.
Have also heard you can solder in a resistor so it tricks it and the light goes out as usual after being fired up.
Look forward to a reply.
Sam. :L
Josh_PoloGTi
Drives: BMW E85 Z4 3.0i
Post by Josh_PoloGTi »
The resistor would be a much better idea than removing the bulb as you won't get the fault code logged on the ECU.
Now I haven't a clue what sort of resistor you need, but I have heard of it being done before, so someone must know the correct type...
smash_it_up_666
Post by smash_it_up_666 »
Did your boss kit not come with the resister?
Me and a mate fitted a momo wheel to his car and the boss kit came with the resistor u need to stick into the airbag wires.
