what dash would be a straight swap for a mk4?
is there any?
cheers
Mk4 dash swap?
dragon_green
you will have to drill holes in teh dash to line up with the exsisting bolt holes. ect also if you wish to fit the TT clocks you will have the have the TT engine to go with them as AFIK the clocks are linked to the ECU and immobaliser. what a bummer that you have to slip a 1.8T engine in to have a set of TT clocks. i know thats the fact with the Audi S3 clocks so im assuming the TT will be the same.
